Big Timing Gear
blgitn
First Name: Roger
Last Name: Harmon
Big Timing Gear
Post by blgitn » Sun Oct 18, 2020 10:00 pm
Can anybody identify the metal timing gear pictured? The number on it is: T415B and looks to be in pretty good condition. I can't locate any reference to that number.
Given the choice, would you install the used metal one of the new nylon one?
R/ Roger.
Re: Big Timing Gear
Post by Steve Jelf » Sun Oct 18, 2020 10:28 pm
415B is the factory number for part #3047B. The parts book says you can use it for all years 1909-1927.
After my bad experience with the failure of a nylon timing gear I would not have another. The same goes for fiber. You can use the original if it's in good condition, or go with bronze (best choice) or aluminum.
Re: Big Timing Gear
Post by RajoRacer » Sun Oct 18, 2020 10:34 pm
The steel 4 spoke was the first helical gear following the straight cut cam gear. I'm assuming following the introduction of the Ford electric starting system.
Re: Big Timing Gear
Post by RajoRacer » Sun Oct 18, 2020 10:35 pm
And, I would use the steel gear, given the choice !
Kerry
Last Name: van Ekeren
Re: Big Timing Gear
Post by Kerry » Sun Oct 18, 2020 10:41 pm
Looking at it will not tell you much, needs to be fitted for a check of lash.
Last Name: Patrick
Re: Big Timing Gear
Post by jiminbartow » Sun Oct 18, 2020 11:43 pm
The only downside to a steel gear is that it is noisier than the non-steel gears. I will take noisier, any day, over a propensity to break and lose teeth like the non steel gears do. Jim Patrick
Re: Big Timing Gear
Post by Steve Jelf » Mon Oct 19, 2020 12:12 am
It's a Model T. You won't hear the timing gear over all the other noises. :D
Alan Long
First Name: Alan
Last Name: Long
Re: Big Timing Gear
Post by Alan Long » Mon Oct 19, 2020 8:29 am
Agree, agree, agree. I too would prefer the noise of a steel gear set over the alternative of a dead engine due to tooth failure.
I believe steel is 100% necessary if running a generator.
Alan in Western Australia
John Codman
Last Name: Codman
Re: Big Timing Gear
Post by John Codman » Mon Oct 19, 2020 10:43 am
I have probably replaced 50 timing gears in modern cars. In every case the change was necessary because the nylon gear failed. If there is any reasonable alternative, I will never install a nylon timing gear. I have also never noticed any difference in the sound of the steel gear as opposed to the nylon gear (actually there was a difference in noise - with the failed nylon gear the engine would not run. With the steel gear installed it would).
Re: Big Timing Gear
Post by Mark Gregush » Mon Oct 19, 2020 11:28 am
And to counter with; when I lost my center main, also broke some of the teeth off the nylon gear, except; only took the top part off some of the teeth and cracked others, the car still ran. The lost teeth were still about 1/2 there and there were cracks were about 1/2 way down the on others. When this happened, I was operating outside my norm. Tried to shift the Warford from underdrive to direct at too high RPM while still on a slight incline. While I may have stripped the remaining 1/2 cracked teeth off later(?), I was able to drive the car off the road before loading on trailer and when got home into the shed.
Re: Big Timing Gear
Post by Original Smith » Mon Oct 19, 2020 11:33 am
There are two types of Ford steel helical gears. Four spoke, and three spoke.
blgitn
First Name: Roger
Last Name: Harmon
Re: Big Timing Gear
Post by blgitn » Mon Oct 19, 2020 4:14 pm
Ok, thanks. Steel it is! I'll check the backlash when I get it together.
Anybody need a nylon one?
R/ Roger.
Les Schubert
First Name: Les
Last Name: Schubert
Re: Big Timing Gear
Post by Les Schubert » Mon Oct 19, 2020 4:43 pm
I’ll take the nylon gear. I’ve run various fiber and nylon gears for 48 years without a problem. But I am scrupulously careful about 100 mm cam to crank spacing and generator gear lash.
Last Name: Hatch
Re: Big Timing Gear
Post by Dan Hatch » Mon Oct 19, 2020 5:00 pm
Was there not a thread a few years ago about some nylon gears made with the wrong angle on the gears. This is what caused the teeth to shear off. Dan
Mopar_man
Last Name: Govoni
Re: Big Timing Gear
Post by Mopar_man » Tue Oct 20, 2020 10:26 am
Ha!! This is so true.
blgitn
First Name: Roger
Last Name: Harmon
Re: Big Timing Gear
Post by blgitn » Tue Oct 20, 2020 7:04 pm
I'll keep you in mind, Les.
R/ Roger.
Re: Big Timing Gear
Post by Allan » Tue Oct 20, 2020 7:29 pm
I read somewhere that some consider the 4 spoke steel gears to be superior to the later 3 spoke type. I can't remember the details. I wonder if all the replacement nylon/fibre/whatever are used for any other reason than either cheapness or noise reduction. My preference has always been for a new steel crankshaft gear and an aluminium timing gear.
Gen3AntiqueAuto
Last Name: Foye
* REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
Re: Big Timing Gear
Post by Gen3AntiqueAuto » Sat Dec 10, 2022 3:46 pm
Old thread but I will chime in. I have sold and installed "a few" nylon timing gears, never heard of one failing unless something stopped the cam from turning first. I have also used aluminum and bronze - they rang like a bell, took them out after a few miles and put fiber or nylon back in.
That being said - I found this thread looking for information on the early straight cut gears. I'm still looking.
Why? "spoilers"... https://youtube.com/shorts/42w_CPoJmN0
Anyone know what year they switched to helical, or any relevent information on straight cut? Are they reproducing them? Advantage / disadvantages?
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
Re: Big Timing Gear
Post by TXGOAT2 » Sat Dec 10, 2022 3:54 pm
Helical gears are stronger and quieter than spur gears. They may introduce some mild side thrust, which would probably add to quiet running. I don't trust nylon gears in auto engines. I would trust an original type bakelite/fabric gear if it was not decades old. Cast iron/streel helical gears are the most reliable, especially where a generator is involved.
RGould1910
Last Name: Gould
Re: Big Timing Gear
Post by RGould1910 » Sat Dec 10, 2022 4:53 pm
I run fiber gears on nongenerator Ts without any issue. Since you can find them in a couple oversizes, it's not difficult to set them up correctly. I wonder if some of the failures we hear about are due to a bent crank or cam. I've seen both.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Big Timing Gear
Post by Dan McEachern » Sat Dec 10, 2022 6:46 pm
The Ford cam gears are not steel they are malleable iron. All Ford T crankshaft gears are steel. Just FYI.
Adam
First Name: Adam
Last Name: Doleshal
Re: Big Timing Gear
Post by Adam » Sat Dec 10, 2022 7:41 pm
If any timing gear “rang like a bell” the centers, or lash, or something else wasn’t quite right…
Art M
First Name: Art
Last Name: Mirtes
Re: Big Timing Gear
Post by Art M » Sat Dec 10, 2022 11:17 pm
Advantages of helical and spur gears
Helical are quieter
Spur or straight tooth are stronger, more efficient, and easier to manufacture
Art Mirtes
Re: Big Timing Gear
Post by Jerry VanOoteghem » Sun Dec 11, 2022 8:40 am
Helical are quieter
Art Mirtes
Helicals are really no more difficult to manufacture than spurs. Usually just requires a different change gear ratio between the gear blank and the spriral hob.
Dan McEachern
First Name: DAN
Re: Big Timing Gear
Post by Dan McEachern » Sun Dec 11, 2022 1:36 pm
Re: Big Timing Gear
Post by Jerry VanOoteghem » Sun Dec 11, 2022 7:31 pm
Helical are quieter
Art Mirtes
Dan's photo above has me a bit humbled. Yes there's a bit more to it than gear ratios.
Re: Big Timing Gear
Post by TXGOAT2 » Tue Dec 13, 2022 10:46 am
I suspect that timing gears in 4 cylinder engines tend to be noisier than those in 6 or 8 cylinder engines, since they are less uniformly driven and loaded. I'd also think that a Model T Ford's low speed 4 cylinder engine, which has no cam-driven oil pump, would tend to have especially noisy timing gears. Lack of a harmonic balancer might further contribute to timing gear noise at certain speeds.
The constant drag of a gear type oil pump would tend to pre-load the timing gears, which would contribute to quieter operation. A generator on a T engine contributes its own noise, adds another gear, and provides very little pre load at low speeds.
