Ammeter question
TheSaintDiscJockey
First Name: Brooks
Last Name: Schlieben
* REQUIRED* Type and Year of Model Ts owned: 1923 TT
Ammeter question
Post by TheSaintDiscJockey » Wed Oct 21, 2020 2:06 pm
When my 1920 T is running on battery or magneto, how should the ammeter read?
If not at all, where should I trouble shoot?
Thanking all in advance.
Last Name: Humble
Board Member Since: 2006
Re: Ammeter question
Post by Humblej » Wed Oct 21, 2020 2:22 pm
Ammeter is on the battery circuit and is separate from magneto. If generator is putting out ammeter should show a pos. If you have no generator output and car is running on bat, and, or the lights are on and or the horn is blowing, the ammeter should show a neg. If the generator is putting out and you see a pos on the ammeter, then turn on the lights, the ammeter may go to zero or into neg. How far pos ammeter goes with lights off depends on how the third brush is set. If you drive the car for long distinces, you should set the third brush to give a low charge. If you drive short dist, set for higher charge.
Stu Tomlinson
First Name: Stuart
Last Name: Tomlinson
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1913 Huckster, 1924 Touring, 1927 Tudor
Post by Stu Tomlinson » Wed Oct 21, 2020 6:20 pm
The meter should read up to 10 amps with the lights off and at a fairly good engine speed. If there is no charge the very first place I would troubleshoot is the generator cut-out. Simply jump around it with a jumper on each of the cutout posts. If it registers a charge then you have found the issue. After that I would use a volt meter to see if the generator is putting out any charge.
Stu
gcomo
First Name: Gary
Last Name: Como
Post by gcomo » Mon Oct 26, 2020 9:36 am
What is the procedure for testing the output of the generator?
Altair
First Name: David
Last Name: Menzies
Board Member Since: 2012
Post by Altair » Mon Oct 26, 2020 10:38 am
I would firstly assure that the commutator is clean, just a slight film of oil will prevent it from charging. The generator should be sealed from the crankcase but a slight vapor leak can contaminate the commutator.
jab35
Last Name: Bartsch
Post by jab35 » Mon Oct 26, 2020 10:39 am
TrashMan
First Name: Chuck
Last Name: Griffin
Post by TrashMan » Mon Oct 26, 2020 11:02 am
So if the ammeter is on the battery circuit, if you run your car on mag, is the battery being charged? I start my car on battery then switch it to mag right away. Does the mag charge the battery?
Post by Norman Kling » Mon Oct 26, 2020 11:44 am
One other thing I will mention. If you are using an alternator, you would show some charge at idle, but on a T generator, it will not show a charge until your engine is either on a fast idle or driving along.
jsaylor
Last Name: Saylor
Post by jsaylor » Mon Oct 26, 2020 11:56 am
"So if the ammeter is on the battery circuit, if you run your car on mag, is the battery being charged? I start my car on battery then switch it to mag right away. Does the mag charge the battery?"
The only thing that changes when you switch to mag is the feed to the coils. Everything else stays with the battery. The generator continues to charge the battery.
Post by TRDxB2 » Mon Oct 26, 2020 12:18 pm
The magneto does not charge the battery but it can be set-up to do so. Remember the magneto puts out AC voltage. But since you have a generator it would be more complicated to do so and then whats the point.
http://www.mtfca.com/discus/messages/70 ... 1498438118
useful discussions on how to charge a battery from your magneto
http://www.mtfca.com/discus/messages/41 ... 1416288062
If you look at the wiring diagram yellow connection points show the path from the generator to the ignition switch and battery. The red connection points are fro the magneto. The ignition switch is actually two switches: the key i used to select the voltage source and the lever to select the lights
