Do you have a TT made December 10, 1925, or later?
Topic author - Posts: 7342
If so, does it have the serial number stamped on the frame like the car frames do?
- First Name: Marv
- Last Name: Konrad
- * REQUIRED* Type and Year of Model Ts owned: '26 TT Steel Cab ("ToyBox Twoo"), '25 Coupe ("Cranky")
- Board Member Since: 2010
Re: Do you have a TT made December 10, 1925, or later?
-Steve-
Our '26 TT has the serial # stamped on the top of the frame, passenger side, inside of the passenger door, I was able to trace it to 'build date' of April 26, 1926. Ironically, it has a replacement engine dated April 26, 1927. Dash pod is rectangular, so there apparently were some earlier parts still being 'used up'.... Hope this helps.
"Let's Figgur it owt!" Just fix it (right), and make it work.....
Aah-OO-Gah! (and), "Happy T-ing!"
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
I have not been able to nail down the exact day of the build, but mine was
tossed together in January, 1926. It has the serial number on the frame where
Marv describes. Interestingly, the frame number is one off from the engine
number.
number.
- First Name: Henry
- Last Name: Petrino
OMG Brent!! Your truck has the wrong engine!!!! Furthermore, there must be another one out there somewhere with the same problem!!!
- First Name: Brent
- Last Name: Burger
.... I know ! I lose sleep over it every night !
