Can i run low head with domed pistons
Topic author - Posts: 85
- First Name: johnny
- Last Name: Buick
- * REQUIRED* Type and Year of Model Ts owned: 1912-13's
- Board Member Since: 2004
I pulled off the high head on my 1912 engine today and i noticed the engine is fitted with fully domed piston heads . The domed pistons run approx 1/2 inch above the block deck. If i was to change to a low head could it become a mechanical catastrophe ?
...An idle mind is the Devils workshop
Re: Can i run low head with domed pistons
I'm not a mechanic but I'll get this back to the top for more experienced guys to discuss, but I would say yes it would be disastrous. Seems to me there's not enough clearance. Maybe I'm wrong, but it's a gut feeling!
- Last Name: van Ekeren
I've never had any problems fitting a stock low head to vendor supplied high domed pistons., and have done several over the years.
Welp, just learned something! So much for my gut.
Thanks Kerry
Thanks Kerry
- Last Name: Matthiesen
It should be OK unless your new low head has been milled a lot. To check put the new head on the engine, run the new head bolts down finger tight with out the head gasket and hand crank listening for parts contact. Pull the head and look for signs of parts contact, if OK install head gasket and torque head. Note that you will need new head bolts because the high head bolts are longer and that this will not work with a after market higher compression head.
- First Name: Bob
- Last Name: Shirley
To check to make sure, take play-doh the kids stuff, roll it out in pancake form about 1/4 inch thick and cover the top of the piston with the piston at the full top position. Set the head on without a gasket and put a few bolts in and snug them. The thickness that the play-doh smashes to is the running clearance.
- First Name: Bruce
- Last Name: Csorba
- * REQUIRED* Type and Year of Model Ts owned: 1915 4 spring Rajo racer, 1917 C-cab van, 1925 Dalgety tourer
Our car runs domed pistons and a milled low head (might be an 1/8th?). Done thousands of miles like that. I'd still do the plasticine thing though.
Bruce
Bruce
Bruce Csorba
Melbourne, Australia
15 4-spring Rajo racer
17 C-cab van
25 "Dalgety" Tourer
17 C-cab van
25 "Dalgety" Tourer
- Last Name: Humble
Johnny, if you are asking if you can go from a later high head to an earlier low head you have some good responses already. The primary difference between a high head and a low head is the water jacket height, not really the combustion chamber height. If you are asking if you can go from a stock head to a high compression head, that would most likely have an interference with your high compression pistons.
- Last Name: Buick
The high head looks to have slight deeper chamber compared to low chamber head pictured darker on the right..the low head chamber also has raised rings where spark plugs come thru ..it could be a problem there..the high head dont have these raised rings .
I will use clay to ensure clearance.
Also the low head as you can see in pic has priming holes , is it mere bolts that screw in to plug when running engine ?
The spark plug boss is over the valves, so no bother there for piston and the primer holes would be 1/8" pipe thread so try a plumber /gas supply shop for plugs for them.
- Last Name: Buick
Beautiful ! ..Thanks Kerry, and to everyone..!
Appreciate it.
Appreciate it.
- Last Name: Buick
When it comes to re-fitting the metal or copper head gasket do i need to apply any gasket sealant or is it ok to go dry ?
- First Name: Mike
- Last Name: Walker
Use Copper-kote gasket sealer on both sides.
Pressure pack of copper seal, buy from Repco, auto barn or super cheap, or you can use brush on silver frost.
Make sure all your head bolt threads are cleaned out, scratch out the crap in the bottom of them and blow out with air. I also use never seize on the head bolt threads.
