Lifting Flywheel
BobShirleyAtlantaTx
Topic author - Posts: 361
- First Name: Bob
- Last Name: Shirley
Lifting Flywheel
this little tool, sure made setting coil ring a lot easier. The bolt locks in the hole in the shaft. No more strong arm lifting the flywheel.
walber
- First Name: Walt
- Last Name: Berdan
Re: Lifting Flywheel
Very Nice!
Tom VanMeeteren
- First Name: Tom
- Last Name: VanMeeteren
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 1923 touring
Would it be possible to show just the tool? I have this project coming up.
BobShirleyAtlantaTx
- First Name: Bob
This is a scrap of 2.25 cold roll about 1.75 long. Bored to 1.1 inch and drilled and taped for a 5/16 bolt. The loop is made from a flower arrangement holder that the local cemetery discards when the get a little rusty. . Call if I can help, Bob at nine o 3-824-1949
I saw this in an old Vintage Ford, I believe - quite simple to make & saves the old back !
Tom VanMeeteren
- First Name: Tom
Thank you. It is more clear now, I just didn't see the hanger loup.
ModelTMark
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1924 TT, 1923 Touring, 1927 Tudor, 1915 Roadster
We manufacture the Model T 3-Point transmission sling in the attached picture, which works great with any shop crane/engine lift. You need a sling that will lift both the transmission and the flywheel as a single assembly, like ours does. If interested, PM me for price and ship dates. Lots sell out quickly when released.
R/Mark, Wms MFG
R/Mark, Wms MFG
- Last Name: House
I easily made a flywheel lifting device like Steve posted. It’s really important to have 3 ‘legs’ of chain and hooks rather than 2. More stable.u
