What is the difference between a Model T and Model A Crankshaft?
Catbird
First Name: Bill
Last Name: Marsh
* REQUIRED* Type and Year of Model Ts owned: 1913 Speedster, 1914 Touring, 1923 Depot Hack, 1925 Calliope, 1926 Pickup, 1927 Speedster
Post by Catbird » Mon Nov 23, 2020 9:29 am
I have heard about people installing a Model A crankshaft in a Model T. What are the advantages? Also, how can I tell if my 1927 Model T speedster has a Model A crank from past owners?
Bill
You can dissect a Model T; but you can’t kill it!
First Name: Henry
Last Name: Lee
Re: What is the difference between a Model T and Model A Crankshaft?
Post by Henry K. Lee » Mon Nov 23, 2020 9:37 am
More torque from the stroke for sure. Larger journals, but some serious mods. Drop the inspection plate and you will know.
Hank
tman1913
Last Name: Bender
* REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
Post by tman1913 » Mon Nov 23, 2020 9:45 am
If the front of the crankshaft at the pulley is threaded and the pan has four bumps on each side where it is bolted to the block, there’s a good chance you have a Model A crank
Remove the inspection cover and have a look
A Model crank has larger mains and rod pins along with a 1/4” longer stroke.
Take a lot more work to put one in but very doable
What Henry said. He types faster. Lol
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Nov 23, 2020 10:55 am
Here is a pic of the pan bumps... and there will usually be a 3/8”-1/2” thick spacer between the pan and inspection cover as well
If you have the inspection pan off, and are not familiar with either crank... the A crank has circular webs near the main journals, and the T crank will look like it was bent up out out of a coat hanger👍
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Tue Nov 24, 2020 12:27 am
I can usually tell if it’s an A crank by the “bumps” on the side of the pan.
Tony Bowker
La Mesa, California
Catbird
First Name: Bill
Last Name: Marsh
Post by Catbird » Tue Nov 24, 2020 9:46 am
Good info! Will check into my engine.
Bill
otrcman
First Name: Dick
Last Name: Fischer
Post by otrcman » Tue Nov 24, 2020 6:41 pm
Somebody correct me if I'm wrong, but I think one of the most significant differences is that the Model A cranks are virtually never found cracked.
Tim Rogers
Last Name: Rogers
Post by Tim Rogers » Tue Nov 24, 2020 7:49 pm
Model T...
Model A...
Catbird
First Name: Bill
Last Name: Marsh
Post by Catbird » Wed Nov 25, 2020 7:09 am
Thank you, Tim Rogers. Opened your post while my wife brought my coffee this morning! She also likes cars. I asked her could she see the difference between Model T and Model A crankshaft. She immediately saw the difference! She said, "The Model A looks 'newer.' " :roll:
Bill
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Wed Nov 25, 2020 10:04 am
The back Main Bearing is also shorter by about 3/8th inch.
I don't recall the exact difference.
