Removing a Starter question
Catbird
First Name: Bill
Last Name: Marsh
* REQUIRED* Type and Year of Model Ts owned: 1913 Speedster, 1914 Touring, 1923 Depot Hack, 1925 Calliope, 1926 Pickup, 1927 Speedster
Post by Catbird » Sun Nov 29, 2020 4:43 pm
Saw a video removing a starter from a car with magneto. They removed the Bendix first and then the starter. They said you should remove the Bendix before removing the starter in a car with a magneto. My car came with an Atwater Kent distributor. Would I be safe to just remove the complete starter from my car?
Bill
You can dissect a Model T; but you can’t kill it!
Last Name: Humble
Board Member Since: 2006
Re: Removing a Starter question
Post by Humblej » Sun Nov 29, 2020 5:05 pm
If the mag ring has been removed, yes, if the mag ring is still there, no.
Last Name: Humble
The addition of a distributor is no indicator if the mag ring is there or not.
Piewagon
Last Name: Regan
* REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout, 1911 Touring, 1912 Delivery Cars (2), 1915 Roadster, 1916 Roadster, 1923 Touring Car
Post by Piewagon » Sun Nov 29, 2020 7:38 pm
The simple fact REMAINS that if you attempt to remove the starter before you remove the bendix you will NOT succeed since the bendix will hit the magneto winding and you will not be able to pry it or shove it or hammer it to get it out. You MUST remove the bendix cover (4 screws) and then remove the bendix which then will allow you to remove the 4 bolts holding the starter and it will simple come right out the front side of the transmission cover. No harm done then. If you have the means of pulling your motor out of the car then go ahead and "attempt" to prove us wrong but once you damage the magneto winding ring you will find that it isn't simply a case of it not working but rather the windings will most likely get tangled up in the magnets and flywheel and you will have to pull the motor to then remove what is left of the mag ring and possibly the magnets as well. Please take the advice you have been given and abandon the idea of removing the starter if the bendix is still in place on the starter shaft.
Hope this helps.
Catbird
First Name: Bill
Last Name: Marsh
Post by Catbird » Sun Nov 29, 2020 9:24 pm
Thank you. Will pull the Bendix first. Looks like no big deal. I have back trouble getting in there. Will get help and do this right.
Bill
Catbird
First Name: Bill
Last Name: Marsh
Hope this helps.
Will do. Thanks again!
Bill
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Sun Nov 29, 2020 11:38 pm
The Ford Service Manual shows how to remove the starter from the car without removing the bendix at all.
William L Vanderburg
1922 Center Door Sedan
Kerry
Last Name: van Ekeren
Post by Kerry » Mon Nov 30, 2020 4:07 am
Not seeing that in my Ford service book Will, remove bendix then withdraw starter.
Last Name: Humble
Post by Humblej » Mon Nov 30, 2020 7:00 am
Ford Service Manual dated 1926, par 953, Removing Starting Motor from Car, states to remove the bendix cover and bendix.
Catbird
First Name: Bill
Last Name: Marsh
Post by Catbird » Mon Nov 30, 2020 7:18 am
I have back problems and was hoping for a simple, quick answer. HOWEVER as most of you agree, I will remove the Bendix first, Thank you for your help.
Bill
Last Name: Juhl
Post by Oldav8tor » Mon Nov 30, 2020 8:20 am
You'll need a extra long screwdriver to remove the screws that hold the cover. You might find it easier to do it from underneath. Removing the Bendix is easy, just be careful not to lose the woodruff key. Also - when reinstalling, be absolutely sure the woodruff key is properly seated.
My back isn't the greatest but I was able to do it. It is also an easy procedure to talk a willing (and more supple volunteer) through :D
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Mon Nov 30, 2020 9:53 am
I am not incorrect in what I said....
If you read paragraph 513 in the FORD SERVICE MANUAL, you can actually remove the starter and bendix as a COMPLETE UNIT.
I've actually read the book from cover to cover, so I knew it was in there.
Post by Mark Gregush » Mon Nov 30, 2020 10:22 am
Chapter XXX ((Model T Ford Service)
Starter Motor Overhaul
953 To Remove the starting motor from the car it is first necessary to disconnect the starting motor to switch cable (See "C" Fig. 35). Lift out mat and floor boards and remove bendix cover and bendix as described in Pars. 894, 896 and 897; the four motor mounting screws are then run out and the starting motor withdrawn.
Chapter XII
Replacing Transmission Bands
(Old Design)
513 Raise front end of the transmission cover and insert a block of wood approximately 2" thick between cover and crankcase (See "A" Fig. 300). This premits removal of starting motor and gasket "B" and Bendix "C", which can be lifted out as one unit. (Fig. 300 shows the block of wood on the starter side between the hogs head and crankcase)
953 would be for pulling the starter without removing the hogs head when quick change bands are installed (or just removing the starter).
513 would be for removing when old style bands were used and hogs head was coming off anyway to replace the bands. The key is the 2" block of wood under the corner to raise the hogs head up so the bendix could pass by the magneto coil ring.
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Mon Nov 30, 2020 10:48 am
Again... it can be done. Do I recommend it? No, I do not.
But....it CAN be done.
Post by John kuehn » Mon Nov 30, 2020 11:06 am
Along the way Ford moved from the old design to a newer design for easier starter removal as shown in the manual. I’m glad he did. it’s amazing what’s in the manual when we read ALL of it.
I had forgotten what’s in the Old design section since my 3 T’s are the newer design cars.
Kerry
Post by Kerry » Mon Nov 30, 2020 3:44 pm
Now Will, of cause lifting the hogs head up will let you remove the starter as a whole but no one is going to do that just to remove a starter, are they? let alone replace it the same way :o That would be a special kind of stupid :lol:
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Mon Nov 30, 2020 3:57 pm
I said the book showed a way to remove it as a whole unit.
Sick and tired of people saying there is no way to do it other than remove the bendix. It was not my intent to tell him to remove it one way or the other... but for you people to just sit here and say that the book doesn’t say but to do it one way, is erroneous.
Now, if you’re calling me stupid, I demand you come to my house and say it to my face.
If not, then just let it go.
Post by Norman Kling » Mon Nov 30, 2020 4:09 pm
Unless you need to remove the hogs head, it would be harder than removing the bendix. Also it is hard to seal the hogs head to transmission and if it doesn't leak, leave it in place.
The one screw on the bendix cover which is toward the right is the hardest one to replace. If your bendix cover has slotted holes for the screws, you can start that screw first and slide the cover under it. You will need a long screwdriver especially to get that one on. Do not lose any of those 4 screws because they have an unusual size thread and hard to find replacements.
Kerry
Post by Kerry » Mon Nov 30, 2020 4:20 pm
Will, I didn't say it wasn't in the service book, I said that I was not seeing it, as for calling you stupid, that would only apply to you if you are considering that removing the starter in that manor was a good idea! or recommend it to some one, as for a face to face debate on the topic, sure just pay for my plane ticket :P
RichardG
Last Name: Grzegorowicz
* REQUIRED* Type and Year of Model Ts owned: 1921 T pickup
Post by RichardG » Mon Nov 30, 2020 5:01 pm
IM WITH --U-- WILL--LETUM NOT PULL THE BENDIX LET--UM--FERGIT TO TAKE THE KEY WAY AFTER THEY WRECK THE MAG COIL,TRYING TO WIGGLE THE BOLT HEADS AROUND AND AFTER ALL THAT FIXIN THERE WAY, THAT KEY THAT THEY FERGOT WILL DESTROY THE TRANSMISSION --WHEN IT DROPS IN AND STICKS TO A MAGNET..THEN FLINGS OFF AND THAT LITTLE BAS%$$^d will destroy every thing under the hogs head, do your t a favor, remove the bendix and before removing the 4 bolts on the starter pluck that key way off and put it somewhere safe...when putting things back,put at least two bolts to hold starter then install the key and bendix-- if it drops this way it will hit the floor..
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Mon Nov 30, 2020 5:10 pm
I turn the keyway of my starter shaft up when I install the bendix.
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Mon Nov 30, 2020 5:11 pm
Ha ha ha. I don't have that kinda cash
Post by TRDxB2 » Mon Nov 30, 2020 10:27 pm
Old thread supports the process "T513, describes a technique of raising the front end of the transmission cover and inserting a 2" block of wood between the cover and crankcase to permit removal of the Starter and Bendix as one unit. "
http://www.mtfca.com/discus/messages/59 ... 1459453224
The alternative process to not disturb the transmission cover gaskets is to slide it out - but requires removing the Bendix for clearance.
Several different processes to do it - just depends on what other maintenance is being done at the same time.
Post by Steve Jelf » Mon Nov 30, 2020 10:40 pm
When you guys have your face-to-face debate, remember to mask up and maintain six feet. :D
Post by Jerry VanOoteghem » Tue Dec 01, 2020 3:38 pm
Sounds like a plan! BTW, here's how I drain my radiator... ;)
Sorry, couldn't resist. :roll:
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Tue Dec 01, 2020 3:42 pm
It's all good. LOL
