1926 Coupe Upholstery
Scott C.
Last Name: Clements
Post by Scott C. » Sat Nov 21, 2020 11:00 pm
I am contemplating new upholstery options for my 26 Coupe. What are your opinions on Classtique vs Cartouche kits?
jab35
Last Name: Bartsch
Re: 1926 Coupe Upholstery
Post by jab35 » Sun Nov 22, 2020 12:19 am
Scott: Classtique has an excellent reputation. jb
Scott C.
Last Name: Clements
Post by Scott C. » Mon Nov 30, 2020 11:17 am
Does it matter if you replace to roof material before, or after the head liner?
jab35
Last Name: Bartsch
Post by jab35 » Mon Nov 30, 2020 11:40 am
Headliner installation is much simpler if done before the top is installed. jb
dunoon
Last Name: Davis
* REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Post by dunoon » Mon Nov 30, 2020 8:50 pm
I had a classique upholstery kit installed in my 26 coupe, t looks great, my installer ( who does upholstery jobs on a lot of very expensive show cars) had it call classique a couple times to have them explain some details.
Scott C.
Last Name: Clements
Post by Scott C. » Tue Dec 01, 2020 1:32 am
I have a loose top bow right above above my my head that rattles real bad. I need to get to it to fasten it down some how.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Tue Dec 01, 2020 10:55 am
On a T enclosed car, you hang the headliner BEFORE you install the top material. (In other words, you hang the headliner with the top covering material off)
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Thu Dec 03, 2020 12:11 am
I had a knowledgeable installer, who does many classic cars, install a Cartouche in my 27 coupe. For him, it was pretty straightforward, but he said that he did have to make a few teeeks or modifications.
Scott C.
Last Name: Clements
Post by Scott C. » Thu Dec 03, 2020 1:26 am
Does the top wood need to be removed? Or, can it be left in place?
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Thu Dec 03, 2020 7:15 am
top wood is left in place, top material goes on anytime after the headliner is installed.
Last Name: Wrenn
Post by TWrenn » Thu Dec 03, 2020 8:41 am
I'll jump in with another "plug" for Classtique! And as in my previous post on Jeff Perkins' thread, Elizabeth of "Class it Up" is a great source
for a perfect install at a reasonable price if you choose to. I am so glad I did!
Scott C.
Last Name: Clements
Post by Scott C. » Fri Dec 11, 2020 11:40 am
Were there any color options for a Coupe in 26? Or, were they all the same?
Last Name: Humble
Post by Humblej » Fri Dec 11, 2020 3:03 pm
Grey upper and grey with green stripe seats and door panels for early-mid 1926 coupe painted channel green. Grey and grey with white stripe for late 1926 and all of 1927 when coupes were painted in several different color options.
Scott C.
Last Name: Clements
Post by Scott C. » Sat Dec 12, 2020 1:45 am
What about early to mid 26 painted black?
Last Name: Humble
Post by Humblej » Sat Dec 12, 2020 7:39 am
Unknown, but it is unlikely coupes were still black by mid year 1926 or even early calender year 1926. Upholstery for a coupe made up to Aug/Sep 1926 should have seats and door panels that would be grey with a green pin stripe. For 1925 production of the 1926 model year it is anyones guess.
Scott C.
Last Name: Clements
Post by Scott C. » Sat Dec 12, 2020 12:03 pm
My VIN is 13648885. I believe that dates it to 5/26/1926. I do not see any evidence of any other color than black. Here is a picture of the interior and the roof. The roof has obviously been replaced long ago.
jab35
Last Name: Bartsch
Post by jab35 » Sat Dec 12, 2020 12:42 pm
Scott: My coupe is 13,606,xxx close date to yours, and mine was channel green, fwiw. You can get 'free' cloth swatch samples from the vendors, for a better idea of color and texture. I believe those samples are from Cartouche.
https://www.modeltford.com/item/SAMPLE-T1.aspx
I'm sure Mike Francis at Classtique would send you swatches at little cost. Nice car, jb
Scott C.
Last Name: Clements
Post by Scott C. » Sat Dec 12, 2020 1:06 pm
I contacted Mike at Classtique and he sent me 3 samples. They were grey with green stripe, grey with red stripe and grey with white stripe. He sent me 3 different options for the head liner, dark grey, a lighter grey and another that looked like a woven vinyl with some brown it. He said that all 26 Coupes were grey. I was curious if my interior was original, or not? Not sure if I want the grey? It might darken the interior quite bit? I have searched the net a little bit and have not found many pictures of a 26 Coupe interior. I am thinking that a tan and brown would look good. He is sending me some more samples from an earlier year.
Scott C.
Last Name: Clements
Post by Scott C. » Sat Dec 12, 2020 1:08 pm
Can someone show a picture of how the top bows fasten at the sides? Mine are loose and rattling. That is what is driving the decision to tear into it.
Last Name: Humble
Post by Humblej » Sat Dec 12, 2020 2:35 pm
A counter sunk screw through the top of the bow into the wood side header.
jab35
Last Name: Bartsch
Post by jab35 » Sat Dec 12, 2020 3:31 pm
Scott C.
Last Name: Clements
Post by Scott C. » Sun Dec 13, 2020 2:02 am
Thanks, that really helps. I should be able to get them snugged down, once I remove the roof material.
Does anyone have pictures of the correct upholstery?
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Sun Dec 13, 2020 4:37 am
My green '26 Coupe has fabric that is green with brown stripes, and tan headlining. I believe it came from a US supplier as a kit around 1990. The carpet is new and home made.
Scott C.
Last Name: Clements
Post by Scott C. » Wed Dec 16, 2020 1:34 am
Surely, some one has pictures of a 26 Coupe with new correct upholstery?
Last Name: Humble
Post by Humblej » Wed Dec 16, 2020 7:52 am
Some good black and white pictures of coupe upholstery are in the Ford Service Bulletins available free on online at cimorelli model t library. December 1925, Vol. 6, No.12, Pg 73-80.
jab35
Last Name: Bartsch
Post by jab35 » Wed Dec 16, 2020 10:57 am
I would follow Mike's guidance. Grey with green stripe is correct for '26 coupe and the headliner grey matched the upholstery grey. Using lesser quality material or mismatched colors does not save you any work, but the choice of colors and fabric is totally up to you. Enjoy the ride! jb
Scott C.
Last Name: Clements
Post by Scott C. » Thu Dec 17, 2020 12:29 pm
I found some original material on the back of the seat!
Scott C.
Last Name: Clements
Post by Scott C. » Thu Dec 17, 2020 12:32 pm
Here are the samples that he sent me.
Grey with green stripe.
Grey with red stripe.
Grey with white stripe.
Scott C.
Last Name: Clements
Post by Scott C. » Thu Dec 17, 2020 12:35 pm
Here are the panel and head liner samples.
Light grey.
Dark grey.
And this.
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Fri Dec 18, 2020 12:07 am
I REALLY like the way that Chrome Oxide Green stripe pop against the gray. It makes what we have now look too dark...
Scott C.
Last Name: Clements
Post by Scott C. » Fri Dec 18, 2020 1:05 am
That's what I think too. I wonder how much the colors have faded over the past 94 years?
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Fri Dec 18, 2020 4:03 am
Scott C's sample is like what I have on my car, but mine was done in 1990.
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Fri Dec 18, 2020 1:42 pm
I think a little of both... but the greens are a different hue (the modern one is too bluish, the other one is definitely a green green)... then again, a lot of options for dyed cloth that were available (and common) in the early part of the last century are for the most part heavily regulated or outright banned - some of the pigments (that have lead, mercury, chromium, etc.) take jumping through hoops and filling out forms to get, where before they were commonly available. (We do historical egg tempera iconography and frescoes - getting the materials can be "interesting" to say the least!)...
If you look closely at the original VS the repop - the repop uses a woven-in thread for the green stripe... the original looks like it was dyed (run through rollers?) over the top of the fabric; it spans 3-4 "courses" of the fabric weave where the new is one course of thread, and has some skips on the edges in places... Regardless, it's fun to see the differences between then and now!
