Front Spring Perch
SIR TIMOTHY
First Name: TIMOTHY
Last Name: ELDER
* REQUIRED* Type and Year of Model Ts owned: 1923 Runabout
Front Spring Perch
Post by SIR TIMOTHY » Mon Dec 07, 2020 12:10 pm
This Model T front spring perch is being offered on a hot rod site I belong to, he says it was sold through Lang's. Does this bolt to the outside of the frame or is the front crossmember removed and this fits inside of the frame? Tim in Omaha
Last Name: House
Re: Front Spring Perch
Post by George House » Mon Dec 07, 2020 3:33 pm
I, ....er, ah,....don’t see a Front spring perch🤪
Post by TRDxB2 » Mon Dec 07, 2020 3:42 pm
It bolts to the frame to lower the front axle (perhaps to much).
video https://www.youtube.com/watch?v=V7dni5Z-k2E
Some similar methods but not the only
Jnverted spring.jpg (62.85 KiB) Viewed 2306 times
Sean B
First Name: Sean
Last Name: Bittle
Post by Sean B » Mon Dec 07, 2020 6:13 pm
Definitely a “period correct” way of lowering a T.
If I remember correctly it is in this book. It explains how to make one yourself.
David Mazza
First Name: David
Last Name: Mazza
* REQUIRED* Type and Year of Model Ts owned: 1925 t runabout
Post by David Mazza » Mon Dec 07, 2020 6:31 pm
Super way to lower the front. The completely original Aldrich roadster is one of the oldest known surviving hotrods. Also happens to be at Lang’s! Wish they would get moving on it, they’ve had it a decade and it still isn’t running 🥺
SIR TIMOTHY
First Name: TIMOTHY
Last Name: ELDER
Post by SIR TIMOTHY » Mon Dec 07, 2020 7:06 pm
Thanks guys, I knew it bolted to the frame, I just needed to know if it was to the outside or the inside and now I know. Pictures worked great. Tim in Omaha
