I am in the process of building a Ruckstell axle for my 1926 pickup. Going by the book I am down to checking the axle housings for being straight. My Ford side (passenger side) looks great, but on the Ruckstell side, the axle is 5/8" out of center at the outside end. I don't see any bend in the Ruckstell housing (P156) tube itself.
Reading an old post from a few years ago, on the subject of bent axle housings, Stan Howell commented that most of the time he had seen a Ruckstell housing (P156) bent it was the cast housing not the tube. I really don't see how the cast part of the housing would bend before the tube but mine is or perhaps it was made that way.
I straightened two 1912 axle housings earlier this year by heat shrinking the tube where it was bent without much trouble. I tried heat shrinking the Ruckstell Cast housing with no luck.
Has anyone else had experience with a bent Ruckstell Housing. Do I throw it on the scrap pile and get another one or is there a way of straightening this thing without having to build some big fixture that would cost more than a new axle housing.
Ruckstell Housing Bent???
rnwilliams
Topic author - Posts: 213
- First Name: Ricky
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 12 Com. Rdstr, 12 Delivery, 2-12 Tou, 15 Tou, 21 Cpe, 25 Cpe 25 TT, 26 TT, 27TT, 26 PU, 26 Tou, 2-26 4dr, 26 Del, 27 4dr
Richard Williams, Humboldt, TN
President, Tennessee T's inc.
- First Name: Henry
- Last Name: Lee
Re: Ruckstell Housing Bent???
Use a plane and depth check to see if the housing is bent. If it not, race the outer sections of the housing tube with a straight edge, mark, heat and bend back. Never seen a Ruxstell casting bend that much the radius rods could not take up.
All the Best,
All the Best,
