Front view of original 24-27 Ford TT Truck needed
SurveyKing
Topic author - Posts: 505
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- Board Member Since: 2014
If someone out there has a frontal view of an original 1924-27 TT Truck, please post it here or email me. We are trying to match the radiator shield and fender apron and want to study original photos. Thank you
- Last Name: House
Re: Front view of original 24-27 Ford TT Truck needed
Keep in mind the “radiator shield” (sheet metal panel covering the bottom radiator tank and through which the crank handle enters) is wider for a TT of 24-27 than for a Model T.
Bunch of photos that you might be able to glean some info from; https://www.google.com/search?newwindow ... 80&bih=854
Even the older era ones, who knows what may have been factory or what might have been replaced. TT's restored today, could be 100% correct or 100% wrong re the radiator shell and fenders or even 50/50.
Dan Haynes
- Last Name: Haynes
It's not a truck, but it's an interesting comparison of the prior low radiator next to the new high radiator.
kelly mt
- Last Name: Kelly
This is my 25 TT.
RustyFords
- First Name: Don
- Last Name: Allen
I like the two "supervisors" bringing up the rear.
1924 Touring
Is there any reason why the TT apron should be different from the car aprons? The radiators are the same. The additional front spring leaf should have nil effect. Are the frame cross members different?
T and TT front crossmembers are different.
TT is Ford part # 1122
Front of late TT with radiator apron
Or, right side up!
Or, right side up!
Dan, the TT cross member looks heavier than the car one, but still the same basic shape. Is there a 9 leaf front spring Y mount with the hole for the extra mounting screw below the crank handle hole? Otherwise the standard radiator apron should still fit, as shown in the photos above.
SurveyKing
- Last Name: Snell
Thanks for the nice photos guys. Allan, sorry, I do not know about the engine mount difference if any on the TT. I was helping Julius Neunhoffer out on a project of his, but will ask him for you next time I see him.
Mark Nunn
- Last Name: Nunn
This photo was taken in '27 but I can't tell what year this TT was from.
