What do the color of these Valves tell me?
1923orange
First Name: Thomas
Last Name: Black
* REQUIRED* Type and Year of Model Ts owned: 1923 touring
Post by 1923orange » Tue Dec 29, 2020 2:08 pm
What can I tell by the color of these valves? The cylinders look/feel great.
Last Name: Humble
Board Member Since: 2006
Re: What do the color of these Valves tell me?
Post by Humblej » Tue Dec 29, 2020 2:24 pm
Look about right to me.
Post by Rich Eagle » Tue Dec 29, 2020 3:00 pm
They don't look bad to me. I don't know if this spark plug info helps any.
I remember charts like that in the 60s. They didn't help me much. Someone who sees these things all the time under varying conditions might know.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Tue Dec 29, 2020 3:06 pm
The little indented areas on the valve top tell you they are original valves that were made in two separate pieces, and the tops were stamped in to attach the mushroom to the stem, using those two holes for that purpose.
Post by Jerry VanOoteghem » Tue Dec 29, 2020 3:16 pm
To add to Jim's observation, the original "two piece" valves should be replaced at your earliest convenience as they are prone to become two-piece valves once again. In other words, the heads like to break off and ruin engines.
By the way, the color looks very normal.
Kerry
Last Name: van Ekeren
Post by Kerry » Tue Dec 29, 2020 3:31 pm
No,
one can't tell if they are two piece valves by the two dimples in the top unless you can see they are cast iron heads, a lot of replacement one piece valves had the dimples for grinding the valves right up into the 1970's+, lifting the valve or looking in the port will tell you.
Post by Jerry VanOoteghem » Tue Dec 29, 2020 7:27 pm
No,
On a couple of those valves, I'm pretty sure I can spot on the top surface of their heads, where the stem is peened. But, you're correct, the only way to be certain is to look into the ports, at the under side of the valve, and look for the pronounced shoulder. Thanks for pointing that out.
1923orange
First Name: Thomas
Last Name: Black
Post by 1923orange » Tue Dec 29, 2020 8:48 pm
Thank you all.
Post by Norman Kling » Thu Dec 31, 2020 11:16 am
You asked about the color of the valves. They look about right to me. The exhaust valves run hotter than the intake, so most of the carbon will be burnt off the exhaust valves.
