Happy motoring into the new year model t drivers. Take a look at this video my friend made this summer of my 14 buzzing up and down his driveway. Boy does that T sound sexy.
https://youtu.be/I8tNauINSCA
Happy Motoring,
Seamus
Happy Motoring into the new year - video link
SMHnat
Topic author - Posts: 53
- First Name: Seamus
- Last Name: Hnat
- * REQUIRED* Type and Year of Model Ts owned: 1914 Ford T Touring
Seamus Hnat
Antique & Collector Car Specialist
Ford Ts As & V8 Cars
Specializing in Precision Tuning & Carburetion & Ignition Systems
Full Service Shop for your Antique Car needs
Richmond, MI 48063
(586) 909 - 2969
smh.restoration@gmail.com
Richmond, MI 48063
(586) 909 - 2969
JohnM
- Last Name: Michaelree
- Board Member Since: 2010
Re: Happy Motoring into the new year - video link
Sounds great, Seamus!
StanHowe
- First Name: Stan
- Last Name: Howe
Now THAT is a good running T!!!!
ivaldes1
- First Name: Ignacio
- Last Name: Valdes
Nice Touring. Is there a toe out on the front wheels? Also how does the engine hand crank stay up like that? Mine doesn't but I am getting older.
He's a McPherson alum.
SMHnat
- Last Name: Hnat
[/img][/image]
[image][/image] It's an original accessory to hold the crank up amd be able to lock it in place. I don't have the correct lock yet. Plus it can hold a license plate. My friend Jeron T gave it to me. I have a set of pristine 1914 plates that were given to me by an Edward E., but they have never been used and shouldn't go on this car.
The toe-in is okay.
Just making a note of the upgrades...
-scat counter balanced crank
- 0.080 aluminum pistons
- .280 stipe cam
- chevy 350 valves
- prus high compression head
- water pump
- U&J carb/intake (using gas pedal attachment)
- distributor
- 12 volt system
- autolite 3095 spark plugs. 2.99 at oreillys
- turbo 400 clutch pack
- disc brakes on rear (tim newbert brake kit)
- ruckstell rearend with 3:1 gears
- led brake lights and turn signals
The toe-in is okay.
- .280 stipe cam
- chevy 350 valves
- water pump
- distributor
- 12 volt system
Seamus Hnat
Richmond, MI 48063
(586) 909 - 2969
Richmond, MI 48063
(586) 909 - 2969
