Stuck fuel shut off valves
David N
Topic author - Posts: 24
- Last Name: Nebelsky
In regards to the brass fuel shut off valves that the parts suppliers sell that are attached at the carburetor, I have installed several on my T and after a year or so they become harder to turn on and off until they get stuck. Is there a way to lubricate the valve to restore it to working order? Right now I have to crawl under my car to turn the fuel on and off at the gas tank and my back doesn't enjoy that too well.
DickC
- First Name: Dick
- Last Name: Cruickshank
Re: Stuck fuel shut off valves
I had that problem with every one of the shut offs. I talked to Lang's and bought a tube of "airplane" lube they sold, it didn't work. Unless you are set on having an original looking shut off, I would go to the newer "ball valve" type. They seal and work!!!
ABoer
- First Name: Anthonie
- Last Name: Boer
I use this valves for years and they works fine .
Toon
Toon
- Last Name: Strange
I take the center out of mine once a month and lube it with EZ turn, works great.
https://www.modeltford.com/item/2902LUB.aspx
troutjohn
- Last Name: Trout
- * REQUIRED* Type and Year of Model Ts owned: 1923 runabout, 1913 touring
I have 2. If you lift up on the handle they turn fine. You can push down on it to reseat after it is turned and in place
Mark, you have more ambition than me!! That's too much work. I have the rather pricey period-correct valve you can only
get through Langs on the '13, works great, always easy, no leaks. On the Fordor I put on a simple, non period-correct "T handle" needle type valve and frankly I love it too! No leaks, very positive on and off. Just my two cents!!
I have the old fashioned shut off valves that Lang's sells on all of my cars, and have never had one stick.
The only "Period Correct" valve is the one on the sediment bulb! However, it is much easier to have one under the hood near the carburetor. Not period correct anyway, so use whichever one you like best!
I didn't like having to use a wrench, and I didn't like the look. So I got rid of it.
http://dauntlessgeezer.com/DG106.html
Dan B
- Last Name: Blaydon
EZ Turn is the stuff you want to use. I put a small amount on the cone of the valve before putting it back together and have never had to have it apart since. Turns EZ!CudaMan wrote: ↑Sun Dec 27, 2020 8:37 amI take the center out of mine once a month and lube it with EZ turn, works great.
John L
- Last Name: Leffler
- * REQUIRED* Type and Year of Model Ts owned: 1923 Coupe, 1927 Touring
Where did you get the shut off valve shown in the third post?
Gasoline has so many additives and driers the gas valve doesn’t have a chance to work without lube.
Apply your favorite penetrating solvent when you notice sticking. Of course, adding MMO to your tank provides good lube and keeps your engine valves from sticking too
- Last Name: Juhl
Good timing! My valve at the carburetor has gotten to the point where I almost need a wrench to turn it. I'm going to take it apart this winter and lube it. Fortunately I have a small can of EZ lube left over from an aircraft building project and plan to use that. I'm glad to learn some have had success with it.
Art M
- First Name: Art
- Last Name: Mirtes
Easy turn lube works for me for about 20 on and off turns. After that, the valve starts to turn harder. Eventually I use a pliers to turn it. I relube it every spring.
I might switch to a different valve.
Art Mirtes
Art Mirtes
Retro54
- First Name: Andrew
Never heard of it. Help a brother out! Ha.Dan B wrote: ↑Sun Dec 27, 2020 2:14 pmEZ Turn is the stuff you want to use. I put a small amount on the cone of the valve before putting it back together and have never had to have it apart since. Turns EZ!CudaMan wrote: ↑Sun Dec 27, 2020 8:37 amI take the center out of mine once a month and lube it with EZ turn, works great.
Art M
- First Name: Art
- Last Name: Mirtes
Lang's sells EZ turn.
Or most any small GA airport that has a parts store - Spencer Aircraft & Aircraft Spruce Specialty online.
