Show Me Your Chevy Disc Wheel Setup!
Tim Rogers
Topic author - Posts: 387
- Last Name: Rogers
Looking for ideas on how to mount 21 inch Chevy wheels for a speedster project...
David Mazza
- Last Name: Mazza
- * REQUIRED* Type and Year of Model Ts owned: 1925 t runabout
Re: Show Me Your Chevy Disc Wheel Setup!
Those di steel wheels look so cool. I do someday want to also do some disc wheels on my roadster. At the moment I’m making aluminum disc covers to jazz my car up a tad. Here are the templates to get an idea what I’m doing.
david_dewey
- Last Name: Dewey
Easy, put them on a Chevy!!
Couldn't resist--Happy New Years!
T'ake care,
David Dewey
David Dewey
I made the spacers for mounting mine. About 7/8-1" thick. Re drilled the holes in the Chevrolet wheels to match the Ford hubs and used the flange plates along with Ford hub bolts. I haven't trimmed off the front ones and rears ended up just right with brake drums attached. Took a while to come up with set of the correct Jaxon rims for them. The 1926/27 and 1928 are different and will not mix and match.
- First Name: Henry
- Last Name: Lee
Still have a few of these sets left.
Ford 6 lug to Chevy 6 lug with offset. Email if interested, with or without hubs mounted.
Hank
Hank
David Mazza
- Last Name: Mazza
Hank, would those adapters properly support 31 chev wheel to model t hub? I know someone who needs this adaptation. Thanks in advance!
- First Name: Henry
- Last Name: Lee
They work perfect! The offset allows you to use Rocky Mountain Brakes.
Hank
Hank
Roz
- First Name: Dennis
- Last Name: P
- * REQUIRED* Type and Year of Model Ts owned: 1926 Ford Touring Car
- Board Member Since: 2014
I like them. Here they are on my speedster. I redrilled the disks to match the T hubs. The disks have a 3” hole through the center, so I made adapters that just slip on the hubs and have a shoulder to fit inside the disk center hole. The adapters are 3/4” thick 6061T6 aluminum. Easy lathe job. They run straight and true. Sorry, I don’t have any close up pictures.
David Mazza
- Last Name: Mazza
Like you read my mind Hank! I passed your contact along. A local friend, also in the group that includes someone named Chad you know. There’s are few of us!
RE the lip for the wheel to center on, I did that also. When the weather allows, I will take photos of them on my 1925 cutdown pickup.Roz wrote: ↑Sat Jan 02, 2021 9:38 pm78298FB9-8D37-42FF-94DE-999A7C230CD1.jpeg
