Help identifying alum pistons
Tlitwin
Last Name: Litwin
* REQUIRED* Type and Year of Model Ts owned: 1926 touring
Post by Tlitwin » Tue Jan 05, 2021 12:08 pm
These pistons came out of motor that was rebuilt in the 60’s. No identifying makes other than “184” on the inside lip. Has strange relief around the wrist pins. Should I reuse them?
Tom
Re: Help identifying alum pistons
Post by Mark Gregush » Tue Jan 05, 2021 12:50 pm
How are the boars? What size are they? How did the car run before taking it down? Don't know who made them, but look to be somewhere between the cast iron and modern aluminum pistons weight wise. Cant tell from the photos, are the rings the larger 1/4" type or narrower? If narrower might want to make sure they are a size that can be found. While others will differ, if everything fits good, I would go ahead and used them. How you drive and how much you drive your car may or may not come into the picture.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Tue Jan 05, 2021 1:59 pm
Look like Jahn's pistons
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Jan 05, 2021 2:11 pm
Not Jahns- they never made a split skirt piston- T slot yes, split skirt-no. Those are pretty crude castings even by Jahns standards. Also the side reliefs are not typical of a Jahns. Hope that helps.
Last Name: Hatch
Post by Dan Hatch » Tue Jan 05, 2021 2:44 pm
Check your piston pin clearance. Just had an engine in here with same piston, piston pin holes were worn bad. Dan
