How to get the wife or GF to go on long tours
Jeff
Last Name: Stevenson
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Post by Jeff » Mon Jan 07, 2019 11:10 am
I found the perfect persuasion device for my wife. It works on the insanely noisy T 6 volt electrical system and has 2 USB charge ports. One for me and one for her iPhone’s hungry power (2amp). 2 wires and Hidden under the dash - it’s 2”x1.5”. So useful!
1921 Touring
"The trick to creativity is knowing how to hide your sources..." Albert Einstein
Tim Rogers
Last Name: Rogers
Re: How to get the wife or GF to go on long tours
Post by Tim Rogers » Mon Jan 07, 2019 11:16 am
Are they for sale?
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Mon Jan 07, 2019 11:25 am
Just don't ask them both at the same time.
1924 Touring
david_dewey
First Name: David
Last Name: Dewey
Post by david_dewey » Mon Jan 07, 2019 3:05 pm
:lol: Um yeah, one might have to be careful there. . . .
T'ake care,
David Dewey
Post by Scott_Conger » Mon Jan 07, 2019 4:54 pm
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Mon Jan 07, 2019 11:38 pm
I used to have a disdain for my wife going along on a Toodle. I've softened some since.
On a tour?
Ya, she'd be on her phone more than helping me to keep watch after a couple miles..
Cool gizmo Jeff!
Jeff
Post by Jeff » Tue Jan 08, 2019 3:02 am
That’s it Scott! Sorry, I should have posted the link. I got all excited that I didn’t have to resize pics!
Jeff
1921 Touring
Tom Hicks
First Name: Thomas
Last Name: Hicks
* REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
Post by Tom Hicks » Tue Jan 08, 2019 3:49 am
My wife will not ride in any of my T's under any circumstances. Fortunately, she is happy when I am happy, and she figures that with amount of time I spend working on T's, I must be happy with them. So no problems!
Curtains are the same situation in reverse. I do not go shopping for curtains with her, and I don't care what kind of curtains she gets as long as she is happy with them. Ditto for furniture, rugs, etc, I am happy when she is happy.
I would like to have her at least take a short ride, but it would take a lot more than a phone charger!
Mindless Automaton
First Name: Kep
Last Name: Kerensky
* REQUIRED* Type and Year of Model Ts owned: 23 truck, 26 bug
Board Member Since: 2011
Post by Mindless Automaton » Tue Jan 08, 2019 4:09 am
Nice looking unit.
Mine had a cool little LED voltage display built in so I can monitor the battery.
I found these work for dashcam's too. Just in case you need one. I have so many videos of people puling out in front of me & then stopping with the driver staring at me doing an impression of a goldfish i figured it might be useful, just is case insurance companies want to see what happened.
Skyler Kimball
First Name: Skyler
Last Name: Kimball
* REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
Post by Skyler Kimball » Tue Jan 08, 2019 9:53 am
Too bad they don't make one of those to run off magneto power... if so I would buy one instantly.
Post by Steve Jelf » Tue Jan 08, 2019 10:16 am
Skyler, you can run it off a magneto indirectly. You run it off a battery charged by the mag. I charge my phone that way.
http://dauntlessgeezer.com/DG102.html
Skyler Kimball
First Name: Skyler
Last Name: Kimball
Post by Skyler Kimball » Tue Jan 08, 2019 10:31 am
Yes, I could Steve... but i do not use any battery at all. I used to use a lawnmower battery, but after it kept dying, I decided to start and drive by mag and have ever since.
Post by Steve Jelf » Tue Jan 08, 2019 10:48 am
I drive by mag too, and sometimes start that way too, but it's handy having the little battery to charge the phone. The mag charger is very simple. In 2½ years of using it my battery hasn't died yet.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Tue Jan 08, 2019 7:44 pm
I will just say,if i decide to get back into having a girlfreind, if I ask her about a ride in the T somewhere and I start hearing chin music about hair and so forth, I will just say bye bye and look for another1. Simpler said that done I know.
Jeff
Post by Jeff » Tue Jan 08, 2019 8:53 pm
Nice looking unit.
You should be able to use any type of USB device, no matter what it is as the 2nd port has a full 2 amps and is plenty of power for pretty much anything I can think of. The 1st port is only rated at 1 amp.
Which device did you get and where from? It would be good for folks to have multiple sources and options.
Jeff
1921 Touring
Mindless Automaton
First Name: Kep
Last Name: Kerensky
Post by Mindless Automaton » Wed Jan 09, 2019 4:28 am
Jeff
aliexpress Dual-USB
Not as clean an install but the volt meter was a nice touch.
Jeff
Post by Jeff » Wed Jan 09, 2019 8:42 am
aliexpress Dual-USB
You must be running a 12volt system....
Specifications on that unit:
Input Voltage: DC12V-24V
Output Current: 3100mA
Material: Aluminum alloy+PC
Work Temperature: 0~40℃
Output Power: 120W
Output Voltage: 5V
The one I use takes 6 volts to power it so it works on all cars with 6 volt systems.
Jeff
1921 Touring
Mindless Automaton
First Name: Kep
Last Name: Kerensky
Post by Mindless Automaton » Wed Jan 09, 2019 6:13 pm
aliexpress Dual-USB
Output Power: 120W
Output Voltage: 5V
Jeff
Mine runs as low as 5 volts. It does try & warn me that it's below 10 volts sometimes though.
"Well duhh it's a 6 volt system"
I also found an arduino power supply will run on 5 volts & output to the USB but the phone thinks that's "Over voltage" according to the warning that pops up on the screen.
Dennis Prince
Last Name: Prince
Post by Dennis Prince » Wed Jan 09, 2019 9:48 pm
My wife likes to go on Model T drives short or multi day drive and one of the reasons is that she can get away from her phone, a lot of the drives and camping trips that we go on are where there is no cell service. I guess that I am just a lucky boy!
BHarper
First Name: Bill
Last Name: Harper
* REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
Post by BHarper » Wed Jan 09, 2019 10:30 pm
Hi Dennis,
I, too, am a lucky fellow in that my girlfriend really likes riding with me in my Model T. She has attended a couple of all day tours and one with less than inviting weather, 45 degrees and a strong wind. She is a trooper.
Yeah, I will have to get for her some period correct cold weather clothing.
Bill Harper
Keene, New Hampshire
