Sheet metal Piston Skirts
MrTwT1915
First Name: Tony
Last Name: Wiltshire
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring 1916 Speedster
Post by MrTwT1915 » Sat Jan 09, 2021 6:06 pm
Does anyone know anything about these Pistons. I also have a set of cross section rods that came with them.
You can see in the first & second photo were they were electrically welded the skirts together.
Piston 1 cropped.jpg (29.9 KiB) Viewed 1705 times
Piston 2 cropped.jpg (24.9 KiB) Viewed 1705 times
Piston 3 cropped.jpg (19.69 KiB) Viewed 1705 times
Piston 4 cropped.jpg (27.51 KiB) Viewed 1705 times
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Sheet metal Piston Skirts
Post by Dan McEachern » Sat Jan 09, 2021 6:37 pm
AFAIK, these were very late 1927 and were supplied by Ford- not aftermarket or replacement. The only complete set I know about was owned by Steve Coniff. Perhaps others can supply additional information, but they were supplied with the X cross-section rods with the built in oil scoop on the cap. The pin was not clamped in the rod, but was full floating with a center lock spring clip similar to the Model A design. The clip retained the pin.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Sat Jan 09, 2021 6:39 pm
Those are the late 27 pistons they call the tin pistons, 7/8 wrist pins in them, most throw them away and use the earlier rods than the X rods.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Sat Jan 09, 2021 6:40 pm
You can use the rods, mill the wrist pin side down to fit modern pistons, rebush the wrist hole to the modern piston size, if you want to sell the X rods they go for 300. a set. with the built in dippers.
