Timer belt interference
LugnutKJM
First Name: Kevin
Last Name: McNamara
Post by LugnutKJM » Tue Jan 12, 2021 12:17 pm
Hi I am brand new to Model Ts (although Ive owned this one for 10 years I just started work on it with my son) When i got it it had a rebuilt motor, so we took the body off and started putting it together. We have it so it runs but the timer lever and rod interfere with the belt when we advance the timing more than 1/2 way. Has a new day timer and 4 blade fan. Any help on this would be greatly appreciated. download/file.php?mode=view&id=78407
Jim Sims
First Name: Jim
Last Name: Sims
* REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Re: Timer belt interference
Post by Jim Sims » Tue Jan 12, 2021 12:23 pm
Not sure if this is your problem, you may want to try a shorter fan belt. This will move the belt away from the timer.
Post by RajoRacer » Tue Jan 12, 2021 12:40 pm
I'm following Jim here - what year T are you referencing ?
LugnutKJM
First Name: Kevin
Last Name: McNamara
Post by LugnutKJM » Tue Jan 12, 2021 12:45 pm
1925 Coupe
Post by John kuehn » Tue Jan 12, 2021 12:46 pm
Like Jim says it’s either using a longer than needed belt, the timer rod needing rebending to clear the belt but from the looks of it without more views a shorter belt may do it.
This sometimes happens when putting an engine together so your not the first.
Post by DanTreace » Tue Jan 12, 2021 1:08 pm
As noted by others, be sure the fan and belt length selected places the fan arm to the lowest position. The fan blade should be very close , about 1” or so to the lower hose.
Also be sure the lower hose is trimmed in length to prevent impingement of the timer rod's full travel.
Once that is checked , if the belt still rides on the timer case, re-check the timing, as the timer rod may be mal-adjusted. Re-time instructions can be found on search of forum posts.
IMG_7139 (580x435) (560x420).jpg (130.72 KiB) Viewed 4235 times
LugnutKJM
First Name: Kevin
Last Name: McNamara
Post by LugnutKJM » Tue Jan 12, 2021 1:24 pm
I will try a shorter belt, seems like the last picture from Dan shows the fan a lot further to the drivers side than mine is, any idea what length you are using? Thanks all for the help.
Post by Jerry VanOoteghem » Tue Jan 12, 2021 1:48 pm
I believe 27" would be the size, IF you're using all stock parts of the correct model year, (lower pulley, fan bracket, fan hub, etc.), and no water pump.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Tue Jan 12, 2021 2:21 pm
I weld and recut the notch on the timer brush to allow the timer to rotate further counter clockwise. You then have plenty of travel before reaching the belt. I find this problem more common on the Anderson timers.
Andy
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Tue Jan 12, 2021 3:11 pm
Andy
For that reason I don't like Anderson timer. I used new day timer as well
Super Mario Bross ;)
1911 Touring
1914 Speedster
Post by Steve Jelf » Tue Jan 12, 2021 3:45 pm
As John says, you're not the first. :D
Divcoone
Last Name: Giles
* REQUIRED* Type and Year of Model Ts owned: Speedster
Post by Divcoone » Tue Jan 12, 2021 5:49 pm
I have a mis-match of parts on a Speedster. With low radiator/high radiator/short fan mount/long fan mount combination possible, things can get complicated. I had a new aluminum fan pulley that I machined to move the belt away from the timer.
LugnutKJM
First Name: Kevin
Last Name: McNamara
Post by LugnutKJM » Wed Jan 13, 2021 12:38 pm
I puled the belt last night and it was 28 1/2 inches so i will try a 27" and let you know.
Post by RajoRacer » Wed Jan 13, 2021 1:35 pm
You found the problem !
NU2theT
Last Name: Wendt
Post by NU2theT » Wed Jan 13, 2021 8:19 pm
This is a good topic and Dan your pictures and comments are very helpful. I noticed some loss of my timer lever travel this fall and my lower hose had move up a tick and caused that same problem.
A replacement radiator for this spring and will trim down and check that lower rad hose again. The forums are priceless.
LugnutKJM
First Name: Kevin
Last Name: McNamara
Post by LugnutKJM » Wed Jan 20, 2021 2:59 pm
An update on my problem, the 27 inch belt fixed the problem thanks for all the pictures and information! On with the project hope to put the body back on by the end of the month.
