What is this for?
What is this for?
Post by TRDxB2 » Tue Jan 19, 2021 7:50 pm
Spacing of the corner holes is the same is early front spring clip
John Warren
Last Name: Warren
Re: What is this for?
Post by John Warren » Tue Jan 19, 2021 8:17 pm
I would say it is a front spring clamp plate that can be used for early and late cars
Post by Allan » Tue Jan 19, 2021 9:02 pm
It could well be from a horse drawn light jinker.
Post by RajoRacer » Tue Jan 19, 2021 10:37 pm
It was an accessory front spring clamp bar - apparently, the earlier double u-bolt bracket was a "better idea" !
Post by DanTreace » Tue Jan 19, 2021 11:03 pm
Spring Plate, added strength to front crossmember to help prevent front spring breakage.
Last Name: Patrick
Post by jiminbartow » Tue Jan 19, 2021 11:54 pm
Dan, you are a virtual cornucopia of knowledge.
I thought it might be used to lower the front end by flattening out the arc of the front spring. Maybe a lower front end was thought to be more trendy and sporty. Jim Patrick
Post by TRDxB2 » Wed Jan 20, 2021 1:31 am
Thank you for the ad - explains the purpose
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Wed Jan 20, 2021 1:35 am
I have one on a TT chassis that saw hard use. Original pictures of TT's at work will sometimes show these.
Scott C.
Last Name: Clements
Post by Scott C. » Wed Jan 20, 2021 1:35 am
My 26 Coupe has one on it.
