Ignition switch
Bill Anziani
First Name: Bill
Last Name: Anziani
Ignition switch
Post by Bill Anziani » Wed Jan 09, 2019 10:33 pm
I had the the switch on my 24 rebuilt by Ben Martin. What a wonderful job! My question is should the lettering on the switch ( BATT MAG DIM) be painted white, or left black. Thanks in advance
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Re: Ignition switch
Post by Charlie B in N.J. » Wed Jan 09, 2019 10:41 pm
Darn hard to see. I wiped some white on mine.
Charles Weisgerber
First Name: Charles
Last Name: Weisgerber
* REQUIRED* Type and Year of Model Ts owned: 1925 Tudor.
Re: Ignition switch
Post by Charles Weisgerber » Wed Jan 09, 2019 11:37 pm
I believe the lettering was white when when the switch was new.
Re: Ignition switch
Post by Allan » Thu Jan 10, 2019 1:33 am
The one on my barn find original 25 model has the white paint.
Re: Ignition switch
Post by DanTreace » Thu Jan 10, 2019 9:40 am
Painted white insert lettering on this early '19 version from print adv. Early switch had various styles of heavy cast plated handles
1926-27 style, NOS switch, non-starter version with headlamp dimmer behind the blank plate... showing factory white lettering
Re: Ignition switch
Post by Original Smith » Thu Jan 10, 2019 9:47 am
I have several never restored originals that clearly show white lettering. How I restored mine was I used white Testor's model paint, and used a very fine small brush. I could only do a few letters on each side of the switch each day until it was done. I then rubbed the area with fine rubbing compound until all that remained was the letters themselves. It's been done ten years now, and still looks very good.
