Brake Pedal Problem
lmitch
Topic author - Posts: 53
- First Name: Lee
- Last Name: Mitchell
Brake Pedal Problem
I'm rebuilding the Hog's Head for a 1925 T. I purchased Brake & Reverse Pedal Supports, Slow Speed Notch, etc... While test fitting today I noticed there is a lot of travel in the brake pedal before engaging the cam. The wear on the pedal cam is excessive. Couldn't find a supplier that carries pedals. After a couple of hours searching these forums, I can't find a solution. Maybe I'm not using the right search phrase. Any suggestions?
- First Name: Henry
- Last Name: Lee
Re: Brake Pedal Problem
Mitch,
I ran it to this issue years back on the replacement pieces. Finally had to take some out of other hogsheads etc and piece them together. I have plenty of pedals and cams, but fitting really is the thing to "your" hogshead.
All the Best,
Hank in Tin-A-See
All the Best,
Hank in Tin-A-See
Remove the shaft build up the cam by welding and file the profile back. If you are going thru all the work I hope you are replacing the shafts anyway.
- First Name: Henry
- Last Name: Lee
Good one Mark, I forgot to mention that!
Hank
Hank
lmitch
- First Name: Lee
Was hoping to just replace clutch shaft. While disassembling today it was clear the reverse and brake shaft needed replacement. The worn out bands led to over adjustment. The band ears wore on shaft threads. I'm don't believe the brakes were working when it was parked back in the 70's. If they were working, they must have made a racket. Some genius installed the bands with steel rivets and the band material was gone.
Got some good photos today but I'm stupid and cannot figure out how to post. Sized them down to 1meg.
MichaelPawelek
- First Name: Michael
- Last Name: Pawelek
Many years ago it was reported that some band material sets were being sold with brass “colored” rivets.lmitch wrote: ↑Sat Mar 02, 2019 10:05 pmWas hoping to just replace clutch shaft. While disassembling today it was clear the reverse and brake shaft needed replacement. The worn out bands led to over adjustment. The band ears wore on shaft threads. I'm don't believe the brakes were working when it was parked back in the 70's. If they were working, they must have made a racket. Some genius installed the bands with steel rivets and the band material was gone.
Unless one tested them out with a magnet they could easily be installed by mistake. Someone with experience would feel the difference bending the ears out but for someone who had never installed band linings before the switch could easily be missed.
Take a few minutes now and straighten and align the pedals, too. You can work them cold just fine. The reverse pedal especially looks a little wonky unless the photo lies.
lmitch
- First Name: Lee
You are correct. The reverse and clutch pedal need adjustment.Scott_conger wrote: ↑Sat Mar 02, 2019 10:27 pmTake a few minutes now and straighten and align the pedals, too. You can work them cold just fine. The reverse pedal especially looks a little wonky unless the photo lies.
You can weld it up as Mark says, or you may find a better pedal at a swap meet. I paid $5 for one at Bakersfield.
I agree with all the above. Also you might find that one or more pedals, usually the brake and low can be bent from pushing hard on them. It is impossible to get the right adjustment without straightening them out and if needed, weld and grind the cam portion of the pedal as Mark says.
lmitch
- First Name: Lee
Thanks for the input. I will weld it up and tool to fit.
