Low head questions
Low head questions
Post by Steve Jelf » Sat Mar 02, 2019 1:21 pm
From what I see in Gail Rodda's Volume 2, this low head would be 1913-1917. Am I reading it correctly? Is there any way to pin it down closer than that?
I gather this means March 24, with no reference to the year.
Has anybody ever deciphered the marks on the water outlet? Some are numbers and some are letters.
Russ T Fender
First Name: Val
Last Name: Soupios
Re: Low head questions
Post by Russ T Fender » Sat Mar 02, 2019 2:04 pm
I have a low head with no markings on it at all. I have always wondered if it is a very early head or an after market item.
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
* REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
Post by Russ_Furstnow » Sat Mar 02, 2019 2:30 pm
Val,
As I researched Canadian Fords, it was clear that many Canadian heads had no markings on them.
I hope this helps,
Russ Furstnow
Last Name: Juhl
Post by Oldav8tor » Sat Mar 02, 2019 2:35 pm
My Sept 1916 engine had a "high" head which I removed when I installed a Z head during rebuild. I copied this from the 1917 section of the encyclopedia: "ENGINE: No major changes from 1916 except for an enlarged “high” head with greater water capacity."
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Post by R.V.Anderson » Sat Mar 02, 2019 3:15 pm
A quick way to identify the '13-'14 (possibly '15 too) heads is to look at the script. It is much higher and much more sharp than on the later heads. It almost looks like the script is a 3/16" thick separate piece attached to the top surface. The '16-'17 heads' script is much flatter and is sort of "smeared" looking.
Russ T Fender
First Name: Val
Last Name: Soupios
Post by Russ T Fender » Sat Mar 02, 2019 4:48 pm
Russ that helps a lot. I didin't think anyone would make an after market low head that was otherwise identical to the Ford head but I didn't have any other explaination. Thanks.
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Sun Mar 03, 2019 10:06 am
This is the original low head on my Sept 1912 Canadian touring , the casting date is above the ford and split by the head bolt one part on each side.As it sits the cast date is not readable. In the summer when the car is out in the sunlight I will have try and read it maybe strip the paint. Cheers Colin
