Stop light
Russ T Fender
First Name: Val
Last Name: Soupios
Stop light
Post by Russ T Fender » Mon Feb 08, 2021 4:27 pm
I have a victor accessory stop light that I thought would fit over a stock T tail light but the tail light on my '22 Centerdoor is too big. The inside diameter of the stop light accessory is 2-3/4". Is there a smaller T tail light that would fit?
Re: Stop light
Post by Rich Eagle » Mon Feb 08, 2021 5:22 pm
I suspect it was made for the 1924 to '27 tail light although I don't have one handy to measure.
https://www.mtfca.com/wp-content/upload ... tl13-1.jpg
Do you want to sell it?
modeltspaz
Last Name: Spaziano
Re: Stop light
Post by modeltspaz » Mon Feb 08, 2021 7:08 pm
I have two of those lights. One is on my '26 Touring, the other one is in my showcase in the garage. Both have the red upper lens with the word "STOP" embossed into the inside of the lens.
They were made to easily mount to a standard Ford taillight bracket that uses the clear teacup lens with the transparent red disc. By simply removing the teacup, red lens, and the stamped steel housing by squeezing the retaining ring, just place the round red lens and clear teacup into the lower portion of the light above. The Victor stoplight can then be placed back on the stock taillight bracket and the stock retaining ring replaced to hold it on. The stock black painted teacup housing can be shelved, or given to a needy Model T associate.
A wire must then be installed to the upper stoplight which should be attached to a stoplight switch.
Probably more information than you wanted, but there you go. No additional charge.
Those were made to fit the rear lights used in the final years of Model T production.
Russ T Fender
First Name: Val
Last Name: Soupios
Re: Stop light
Post by Russ T Fender » Mon Feb 08, 2021 7:36 pm
Thanks for the information your description clears things up. I will track down a later tail light to use.
Re: Stop light
Post by Mark Gregush » Mon Feb 08, 2021 7:47 pm
The later cup mounts to the license plate bracket, it's not stand alone. The bracket is made to retain the snap ring the hold the cup in place.
viewtopic.php?t=2973
This one is really good;
http://www.mtfca.com/discus/messages/33 ... 1382887081
Re: Stop light
Post by DanTreace » Mon Feb 08, 2021 7:48 pm
Here is adv. for that style stop lamp for the '24-'27 tail lamp/license bracket assembly.
