Problems finding neutral ??
Larry e rutt
Topic author - Posts: 154
- Last Name: Rutt
- * REQUIRED* Type and Year of Model Ts owned: 1926 fordor
Ok... so I have a 26 that sat for about 40 years, transmission is tight. If I put the parking break on it is almost impossible to crank though I can turn it .I can start it by jacking up the rear wheels and then after it warms up a bit hit the brakes..seems high gear is tight / stuck.. I drive it around town a few miles then park it, next morning tight again. It's been cold here in pa, will this free up when it warms up ? I took the cover off the transmission and watched the disengage and engage action.. those little fingers barely get touched because that barely move at all. Is this how that works ? Or should there be more movement there? Any help or suggestions would be greatly appreciated..
Re: Problems finding neutral ??
The clutch contains 13 large disks alternating with 12 smaller disks. The smaller disks are turned by a drum on the main shaft from the engine. When the clutch spring is released it squeezes all the disks together so that the smaller ones turn the larger ones which turn the brake drum which turns the tail shaft, U-joint, drive shaft, rear axles, and wheels. When you pull back on the lever or step on the low pedal the spring is compressed, the large and small disks are free to turn separately, and you have neutral. BUT cold oil tends to act as sort of a semi-glue that makes the disks want to turn together. This acts as a drag on the engine, making it harder to start. It also makes the car want to creep forward when the engine does start. I expect this is what you mean when you say the transmission is tight. There are two things people do to deal with this. One is to chock the wheels and park with the lever all the way forward to squeeze the oil out of the disks, then pull it back to neutral to start. The other is to jack a rear wheel off the floor and let it spin when starting, so there's no resistance to the engine turning.
George N Lake Ozark
- First Name: George P
- Last Name: Clipner
What kind of oil are you using. Not to start a fight here, but if you are using a straight weight 30 it could cause that in real cold temps.
JWalters
- First Name: Jason
- Last Name: Walters
The original all steel disc setup will always drag on cold start no matter what you do.
Jason
does your 1/2 page ad make you much money?
JWalters
- First Name: Jason
Scott
Doesn't make me anything other than helpful.
Does your half page ad for float valves make you much money?
ewdysar
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
That’s funny, I had never noticed the tiny print in Scott’s signature section until Jason mentioned it. However, the full color photos in various members’ sig section, including Jason’s, I find distracting from most conversations because I try to figure out what they have to do with the topic at hand. By what appears to be sheer coincidence, Jason’s advert directly supports his opinion in this thread.
That said, I’ve never had much of a problem with the stock steel clutch disks. It never gets too cold here, and I park my ‘14 with chocks and handbrake forward during the winter. When I forget and leave the handbrake on, the car can be a little hard to crank by hand until she runs long enough to open the choke all the way. The handbrake seems to have no issues preventing “car creep” when starting cold. And in my experience, with an electric start, there have been no issues with cold start drag at all.
Keep crankin’
Eric
Keep crankin’
Eric
JWalters
- First Name: Jason
Scott's signature is an advertisement of his product for financial gain. Mine is not.
Then just scroll right past them. easily done.
Just like yours, my signature line contains an opinion...just a lot smaller and with no pictures to distract
Joss
- First Name: Joss
- Last Name: Sanderson
You say the car has sat for some 40 years? If so the discs are likely coated with a varnish. Two suggestions might help. First is to drain the oil and add a gallon of kerosene - this is what the old timers did. Then with at least one rear wheel securely blocked up start the car and work the high low pedal in and out multiple times. Just fine to run for a couple minutes. The kero will clean a lot of the old crud. Then drain and put in fresh oil.
I have seen many an old engine come back to life doing this.
JWalters
- First Name: Jason
Have you stopped modifying and selling float valves?Scott_conger wrote: ↑Tue Mar 05, 2019 11:56 amJust like yours, my signature line contains an opinion.
Do as Joss says and if things still don’t seem right place the car on a flat surface. Place the hand brake in neutral position (straight up).
Try to turn the crank and if the car moves the clutch linkage or or the clutch itself might need adjustment.
If the adjustment is correct the car won’t move when the handbrake is placed in the straight up position. That’s neutral.
Larry e rutt
- Last Name: Rutt
Ok thanks.. I did get some good advice and suggestions, I appreciate it. I think I might hang on till spring and see what happens..if I'm not satisfied with the way it works I might try the kerosene as a cleaner.
