Transmission Inspection Cover, Plexiglass.
Pep C Strebeck
First Name: Joseph
Last Name: M
Post by Pep C Strebeck » Tue Feb 23, 2021 2:43 pm
I don't know if videos of this had been posted before but I came across these last night and thought I would share a couple of the links. The standard inspection cover was changed out with a plexiglass one so you can see what is happening inside.
https://www.youtube.com/watch?v=2m-za3o-lWo
https://www.youtube.com/watch?v=JqW1g0xBPHA
https://www.youtube.com/watch?v=3G5SxOqBKZw
These next 2 show it with a filter screen and magnet installed. The first one is of the "standard" screen and the second one is a comparison with one that has been modified with larger holes. It seems as though the screen with the larger holes (increased flow rate) would allow more of the foreign material to stay in suspension in the oil and then be washed out and not caught by the screen. I don't think that I am a fan of that modification.
https://www.youtube.com/watch?v=I1w2vFTRUvQ
https://www.youtube.com/watch?v=dXimnKoDPSI
Last edited by Pep C Strebeck on Tue Feb 23, 2021 9:01 pm, edited 1 time in total.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Transmission Inspection Cover, Plexiglass.
Post by ThreePedalTapDancer » Tue Feb 23, 2021 2:53 pm
That is interesting.
Post by TRDxB2 » Tue Feb 23, 2021 4:37 pm
Bud Delong
First Name: Kenneth
Last Name: DeLong
Post by Bud Delong » Tue Feb 23, 2021 8:18 pm
About 20 years ago!! Bud. :D
Pep C Strebeck
First Name: Joseph
Last Name: M
Post by Pep C Strebeck » Tue Feb 23, 2021 9:00 pm
Yes it was posted before - BUT no video's were indicated
I guess I should clarify; I don't know if any VIDEOS of this have been posted before? It does not look like that is the case, although there are previous threads on the topic that do include photographs.
Scott C.
Last Name: Clements
Post by Scott C. » Wed Feb 24, 2021 1:18 am
Yes, they were posted on here last year.
viewtopic.php?f=2&t=12546&p=94627#p94627
John Warren
Last Name: Warren
Post by John Warren » Wed Feb 24, 2021 10:20 am
Thanks Joe for re-posting. It is the first time that I have seen " IT " and it was great seeing the transmission in action.
It's Bill
First Name: Bill
Last Name: Hoffer
Post by It's Bill » Wed Feb 24, 2021 4:37 pm
I am new to Ts, so this is all good. Thanks for posting! Cheers, Bill
It's Bill
First Name: Bill
Last Name: Hoffer
Post by It's Bill » Wed Feb 24, 2021 5:13 pm
So I looked at these again, and it seems that the screen does a better job of evenly distributing the oil across the length of the transmission. The unmodified screen looks like it starves the rear section of oil, but by drilling larger holes in the screen the oil flows more freely to the clutch area. Is there an optimal size and arrangement of screen holes to help the different sections of the transmission get the best amount of oil? Does his hole pattern deliver too much oil to the clutch area at the expense of the bands? And does the filtering of trash trump oil delivery?
Overthinking in PA, Bill
Post by DanTreace » Wed Feb 24, 2021 5:44 pm
Bill
Just this afternoon, changed the oil in Nellie the '23 cutoff. Part of each oil change is to pull the inspection cover and see what's in the oil screen. Mine is modified with larger holes (using a simple step-drill) and I do think it adds more oil to the bands that way. And the screen still does the clearing of stuff floating around just super. ;)
Look closely and see the band springs under the larger holes.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Wed Feb 24, 2021 9:59 pm
That is more exciting if you leave the cover off and start the engine.
An old trick to play on new Model T owners.
Last Name: Hjortnaes
Post by DHort » Wed Feb 24, 2021 11:48 pm
Jim
Will it start better that way?
Bill
Remember that the transmission is still full of oil. If you drill too many large holes in the filter it does not filter as well anymore. I think the main purpose of the screen is to filter and not distribute oil farther to the back. To each his own.
It's Bill
First Name: Bill
Last Name: Hoffer
Post by It's Bill » Thu Feb 25, 2021 7:51 am
It would be tricky to get the flow balanced and optimized for sure. I guess more flow is needed to the bands than to the clutch, and filtering out the trash is definitely desireable. Dan's modification looks pretty good to me...
