Desperately need pictures of a 1909 T roadster buggy rail top installation
Burlingtontguy
Last Name: Michaud
* REQUIRED* Type and Year of Model Ts owned: 1909 roadster, 1911 mother-in-law, 1912 torpedo, 1912 touring
Board Member Since: 2010
Post by Burlingtontguy » Fri Feb 26, 2021 10:30 am
I hope someone can send me pictures of a 1909 Mother-in-law Roadster top to buggy rail installation showing the hardware , roll up window and straps as I have the buggy rail but no images of it mounted at the seat, Any help would be appreciated, Thanks Dennis
Re: Desperately need pictures of a 1909 T roadster buggy rail top installation
Post by DanTreace » Fri Feb 26, 2021 5:21 pm
These may help on the seat irons, shots of my reproduction '09, may not be totally factory. Two long irons on each side, and two shorter irons on the backrest. The buggy rail bolts to these irons.
buggy rail outer view forum.jpg (46.25 KiB) Viewed 1911 times
buggy rail forum.jpg (55.52 KiB) Viewed 1911 times
The top prop iron is wrong year in this photo. The prop irons are a split yoke type with two mounting holes.
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Fri Feb 26, 2021 10:56 pm
This may confuse the issue but I have a picture of Kim Dobbins original 1910 touring top irons. The picture shows the iron which was different from my 1909, which I suspect was a not completely accurate reproduction.
Top iron support, 1910 Model T
The bolts you see going into the body are supported on inside by irons rising from the body floor. I believe mine are similar to those shown in earlier pictures in this thread.
Tony Bowker
La Mesa, California
W Austen
First Name: Bill
Last Name: Austen
Post by W Austen » Sun Feb 28, 2021 4:58 pm
I think what you need is in Bruces encyclopedia on pages 57 -60 very good pictures of a very original 09 roadster. Maybe some one could up load the pictures if you don't have the book.
