License plate restoration
Executive Director
Last Name: Bumgarner
Post by Executive Director » Fri Mar 05, 2021 10:26 am
Looking for a license plate restoration shop.
John iaccino
Last Name: Iaccino
* REQUIRED* Type and Year of Model Ts owned: 1911 Roadster, Open Runnabout
Re: License plate restoration
Post by John iaccino » Fri Mar 05, 2021 11:33 am
After painting the background color, I took my plates to a Fast Signs store where they made the numbers out of black vinyl and put them on the plates for $10 per plate. Worth a try to see if they will do it for you.
Post by DanTreace » Fri Mar 05, 2021 12:53 pm
Steve
A list of some of the better, they are members of the vintage plate group.
https://www.alpca.org/faq/restorers/
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Fri Mar 05, 2021 2:00 pm
Steve- I sent you a PM. Dan
Brent Mize
First Name: Brent
Last Name: Mize
* REQUIRED* Type and Year of Model Ts owned: 1927 Sport Touring & 1927 Sport Runabout
Post by Brent Mize » Fri Mar 05, 2021 4:06 pm
Brian Mabry just did these for me.
Beautiful work.
It usually takes about 4 months.
https://finishyourplates.com/about-the-business
Brent
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Fri Mar 05, 2021 4:17 pm
My father is a license plate collector.
When he restores a plate, he paints the background himself and has a professional sign painter and pin striper paint the numbers and letters.
For backgrounds that are not black, white or silver, he goes to an automotive paint supply and has a digital color match done by having them scan a good original plate from the same year for the sample and purchases the paint packed into rattle can.
NorthSouth
Last Name: California
Post by NorthSouth » Fri Mar 05, 2021 4:24 pm
I had these made from scratch by a local sign shop using my damaged original pair as a guide.
They are the same size just positioned one behind the other.
1915 CA License Plates
Rich in Colorado
Last Name: Carlson
* REQUIRED* Type and Year of Model Ts owned: 1922 Center Door 1923 Touring
Post by Rich in Colorado » Fri Mar 05, 2021 8:29 pm
I used Larry Scott a few times. I noticed he was on the list that Dan posted. Larry does have a "real" job so if you are looking for a two day turn, not going to happen. He is in Denver, but I mail my plates to him even though I'm only about 30 miles away. Reasonable. Priced on how much work he needs to do. I sand blast mine before sending, helps with the cost.
Before
After
I assume he does plates from all states
Good Luck Steve,
Rich in Colorado
1922 Model T Center Door
1923 Model T Touring
1928 Model A Tudor
1956 Ford Thunderbird
1966 Ford F250 Camper Special
Chris Haynes
First Name: Chris
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Post by Chris Haynes » Fri Mar 05, 2021 10:57 pm
Just a heads up for guys in CA. Take your unrestored plates to the DMV to get them registered to your car. Why? Because they won't accept a restored plate.
Post by Steve Jelf » Sat Mar 06, 2021 12:35 am
Other states require them to be restored. Both requirements are supremely stupid. How can they tell the difference between an NOS plate and a properly restored one? They can't.
Post by TRDxB2 » Sat Mar 06, 2021 1:53 am
Likely :roll:
troutjohn
Last Name: Trout
* REQUIRED* Type and Year of Model Ts owned: 1923 runabout, 1913 touring
Post by troutjohn » Sat Mar 06, 2021 8:50 am
Larry Scott does great work. I have several plates done by him.
