Multi lift Junior
Khill0105
First Name: Kyle
Last Name: Hill
* REQUIRED* Type and Year of Model Ts owned: 1925 depot hack. 1924 4door 1920s racer 1923 TT
Multi lift Junior
Post by Khill0105 » Tue Mar 09, 2021 9:09 pm
Looking for pictures of the multi lift junior. I’ve searched the forum and have read several posts on the subject but no pictures. If anyone has a set or pictures could you please post them. If you have a set could you please post a picture with a ruler in the picture also.
Thanks everyone Kyle
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Multi lift Junior
Post by ThreePedalTapDancer » Tue Mar 09, 2021 9:49 pm
Mike Penserini
Last Name: Penserini
* REQUIRED* Type and Year of Model Ts owned: 27 roadster pickup, brass speedster, Mercury # 253 B, Mercury # 1070, Faultless "Hoosier" parts collection.
Post by Mike Penserini » Tue Mar 09, 2021 10:43 pm
The late Jerry Hunt reproduced Multi Lifts a while back and sets pop up from time to time. When Riley was originally making his Multi Lifts he was also producing a head to be used with them.
Khill0105
First Name: Kyle
Last Name: Hill
Post by Khill0105 » Wed Mar 10, 2021 3:52 pm
Thanks so much guys for the pictures and the links. I think I’m definitely going to have to try to make a set
Post by speedytinc » Wed Mar 10, 2021 4:28 pm
I installed a NOS set in my 14. Used a reground cam with .230 lift with model A cam durations. (seemed like the perfect cam), New stainless valves & stock springs. VERY DISAPPOINTING RESULTS.
At first it ran well. not a world beater, but well.
with in a year, it started running on 3 & back popping thru the carb. determined #4 exhaust was barely opening.
When i opened the valve covers for a look, i couldnt believe the mess.
One upper pivot pin was shattererd, 2 were in place broke, 4 of the valve stems had a 3/4"radius worn away a good 1/4"+ up the stem where upper lift arms contacted.
EVERYTHING WENT WRONG.
Any body running these things successfully?
What could i have done so wrong?
DustySpokes
First Name: Edmund
Last Name: Niedzielski
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
Post by DustySpokes » Thu Dec 09, 2021 8:15 pm
A question that is related to the double spark head. I finally got one after a looong quest. What spark plugs are best suited for these heads ? As to the lifters, I wonder if it is a challenge to get the bases locked down good and tight so that they do not move ?
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Thu Dec 09, 2021 8:26 pm
I have a set of new reproduction multi lifts. I am thinking about installing them just on the intake valves. I know some people that have run them quite successfully
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Dec 09, 2021 9:00 pm
Heres a set for $410.00 with shipping.
Hank
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Dec 10, 2021 2:58 pm
The device for holding the multilifts in place and lubrication seems to be the big issue. The very colorfull pictures show a beefed up version as for this picture. Running a line from the hogshead or drip oilers may solve the lubrication issue
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Dec 10, 2021 3:06 pm
I have also heard mention of a device to hold the framework centered in place over the tappet bosses.
Craig
