New exhaust pipe for Model T
Kajtek1
First Name: Kris
Last Name: Pawlak
* REQUIRED* Type and Year of Model Ts owned: 1922
Post by Kajtek1 » Thu Mar 18, 2021 6:48 pm
I found old topics where there was Larry from CA making new pipes, but seems he is no longer a member here and I can't find him on google.
Are new pipes available? Mine has crack along the weld, so it might be weldable, but I like new idea better.
Re: New exhaust pipe for Model T
Post by Mark Gregush » Thu Mar 18, 2021 7:06 pm
Yes he is a member and last I knew had sold all the he made. His handle is "Original Smith"
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Fri Mar 19, 2021 12:28 am
Kris, You didn't say what year T that you have, The pipes that Larry Smith had made up were duplicates of the original pipe used by Ford with the original pressed steel end muffler. They wouldn't work with any original cast iron end muffler or even a modern reproduction pressed steel end muffler, without modification, and maybe not even then. They are longer because the pipe goes all the way through the muffler from the front steel end to the rear, replacing the smallest inner tube normally found in Model T take apart mufflers. Recently, he posted here on the forum that he had no intentions of having anymore made up, as they were a 'pain in the arse to ship. The guys, like me, who bit the bait when he made them are the lucky devils.
Kajtek1
First Name: Kris
Last Name: Pawlak
Post by Kajtek1 » Fri Mar 19, 2021 1:06 am
It is 1922 model and I think I have cast iron muffler, but have to check it closer.
Sounds like welding old pipe is my only option?
Post by Mark Gregush » Fri Mar 19, 2021 1:10 am
The new pipes sold by the suppliers may not be exactly correct, they will work.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sun Mar 21, 2021 1:16 am
Any of the modern reproduction pipes, should work on a 22 T. Depending on the manufacturer who supplies the vendor, there may be variances in pipes from one vendor to another. I read where the ones from Lang's worked well for one owner.
danungar
First Name: Daniel
Last Name: Ungar
* REQUIRED* Type and Year of Model Ts owned: 1922 Center Door Sedan
Post by danungar » Thu Mar 25, 2021 11:14 pm
I purchased and installed the stainless steel exhaust pipe that Lang’s sells. It was a bit too long on the back end, but with a $15 pipe cutter from Harbor Freight I was able to shorten it to the correct length and now it fits like a glove. It’s the shiniest thing under the car, no regrets and definitely worth the extra $40 upgrade from the basic steel version they also sell.
Post by Mark Gregush » Thu Mar 25, 2021 11:23 pm
The pipes come a little too long so they can be trimmed to fit as needed, if needed.
John Codman
Last Name: Codman
Post by John Codman » Fri Mar 26, 2021 11:31 am
Lang's part #4037C. If you want it in stainless it's part #4037CSS. When I bought mine it fit perfectly.
Post by Original Smith » Fri Mar 26, 2021 11:35 am
Too bad a T person with lots of money can't come forward to make the last style exhaust pipe for our cars. If Ford, and others could do it back then, it can be done again! There is apparently not enough interest. I have a NOS original Ford script pipe that we used for a pattern, but were not able to use the exact Ford method for making them.
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring(2), 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Post by rickd » Fri Mar 26, 2021 1:39 pm
I just looked at Snyders and they list an exhaust pipe for 09-27 Model T. Looks like you have some options.
Post by RajoRacer » Fri Mar 26, 2021 4:09 pm
Some DON'T fit !
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Fri Mar 26, 2021 8:02 pm
I'm making my own from stainless handrail, if I ever finish that project.
Vern (Vieux Carre)
danungar
First Name: Daniel
Last Name: Ungar
Post by danungar » Fri Mar 26, 2021 8:32 pm
If you’re planning to replace the muffler too (I had to, the entire thing was rusted beyond repair) make sure you test fit the new muffler on your new pipe to make sure the two will correctly mate. The welded muffler that I ordered from Lang’s was manufactured incorrectly and the I.D. Of the muffler was just a smidge too small to accept the new exhaust pipe. Lang’s was great about swapping it out, but just something to be aware of.
Post by Allan » Mon Mar 29, 2021 2:33 am
If Larry's pipes were made like the Canadian ones, that would overcome the need for the raised upset in the pipe that is so difficult to achieve.
Last Name: Hjortnaes
Post by DHort » Mon Mar 29, 2021 3:05 am
I believe it is the F11 tractor muffler that costs less than $30, and it works fine. Many speedsters do not use a muffler, just a straight pipe.
