Ben Martin Rebuilt Ignition Switch
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Mon Mar 22, 2021 5:58 pm
Does anyone have any pictures/info on Ben Martin's switches. I picked up a very nice '20's era switch at Chickasha. It has a phenolic back, so I thought maybe a repro, but it has a #70key so I don't think it is. It seems to work very smooth and seems to be very good quality. Any thoughts? Thanks in advance, Dave
1925 mostly original coupe.
Last Name: Humble
Board Member Since: 2006
Re: Ben Martin Rebuilt Ignition Switch
Post by Humblej » Mon Mar 22, 2021 7:05 pm
Ben uses only original parts that he flattens and embeds with glue. His work is top flight. If it looks like it might have new parts it would not be his.
Post by DanTreace » Mon Mar 22, 2021 8:51 pm
Original switch backing is a laminated cardboard like insulator, the plastic is a modern reproduction.
26671 copy.jpg (57.41 KiB) Viewed 5423 times
Backside of a Ben Martin rebuild. The original laminate wafer terminal back is repaired and then sealed in clear epoxy.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Mon Mar 22, 2021 8:57 pm
Is he still around and doing these?
John.Zibell
Last Name: Zibell
Post by John.Zibell » Mon Mar 22, 2021 9:13 pm
Actually on my switch (pin type) he used a quality reproduction I can't remember the source for the switch back but it is a very good part and will likely out last any original.
1926 Tudor
Randall strickland
First Name: Randall
Last Name: Strickland
Post by Randall strickland » Mon Mar 22, 2021 10:10 pm
Ben Martin
7seven 0 nine 3 8 337six
four zero 4 789 six 3 five 0
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Mon Mar 22, 2021 10:19 pm
Thanks Randall
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Tue Mar 23, 2021 12:15 am
Ben is definitely still around. He's been advertising in the MTFCI magazine to buy rebuild able switches.
Post by TRDxB2 » Tue Mar 23, 2021 12:52 am
For awhile Langs was out of the switch plates there current online catalogue shows some descent looking ones versus the old phenolic back. May need to check if they have stock now
CraneJon
First Name: jon
Last Name: crane
* REQUIRED* Type and Year of Model Ts owned: 1925 T pickup, 1928 A, 1931 A
Post by CraneJon » Tue Mar 23, 2021 1:12 am
Ben Martin is the only place to go for a rebuilt T switch. Very pleasant to call talk to, fair prices, and HIGHEST quality. Cannot ask for more than that
Jon
Novice
First Name: Jim
Last Name: Davis
Burnt Plastic
Post by Novice » Tue Mar 23, 2021 1:15 am
Old plastic reproduction switches would start to melt if a connection got hot. my 26 touring had one on it. first night I turned the lights on sparks flew out of the switch and it reeked of burnt plastic. replaced it with a Ben Martin switch. and installed a inline fuse holder on the hot wire coming from the starter switch at the firewall terminals.
Darin Hull
First Name: Darin
Last Name: Hull
* REQUIRED* Type and Year of Model Ts owned: 1913 Model T & 1926 Model T project
Board Member Since: 2010
Post by Darin Hull » Tue Mar 23, 2021 9:07 am
Ben is doing good, I’ve spoke to him a few times recently. He said he’s still rebuilding switches but always on the look for components to keep up his rebuilds. Apparently that is an ever increasing struggle.
Ben has become one of the founding members of the Southern Peach T’s as our club seeks official recognition as the first Georgia MTFCA chapter.
Darin
Post by John kuehn » Tue Mar 23, 2021 9:50 am
The reproduction switch back from Lang’s is what I used for my switch. It’s works fine and is a well made piece. It’s made of some sort of black material that’s not plastic I don’t think and is pretty durable.
Ford would have used this type of material if it was available I’ll bet.
D Stroud
First Name: David
Last Name: Stroud
Post by D Stroud » Tue Mar 23, 2021 9:59 pm
Thanks guys. Dave
