Crankshaft repair???
Steve Bender
Last Name: Bender
* REQUIRED* Type and Year of Model Ts owned: 1923 auto polo car
Post by Steve Bender » Wed Mar 24, 2021 8:20 pm
I purchased this crankshaft at Chickashee and cleaned it up to use in a spare engine. There appears that someone used brazing on the inside of the third main. Why would they do this? Is there anyway to clean it up?
Kerry
Last Name: van Ekeren
Re: Crankshaft repair???
Post by Kerry » Wed Mar 24, 2021 8:47 pm
Trying to take out the float end play of the worn thrust babbit in the 3rd bearing cap.
it would be easy enough to turn it off in a lathe and then have it crack tested, myself I wouldn't use it, a lot of heat has gone into that shaft to make brazing stick.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Wed Mar 24, 2021 9:39 pm
Wouldn’t bother me... if it wuz holding up my mailbox😉
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Thu Mar 25, 2021 12:11 am
Attempted end play repair. Not recommended.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Thu Mar 25, 2021 12:44 am
Sounds like someone "took" you.
Steve Bender
Last Name: Bender
Post by Steve Bender » Thu Mar 25, 2021 6:22 am
I don't think the person selling it knew. It was covered in thick old grease and appeared so for a very long time all the journals are round and measure close to standard so we thought it was a good one until I got home and cleaned it up. I don't understand why you would do this to fix the end play instead of working on the cap??
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Mar 25, 2021 6:32 am
Someone had an oxygen/acetylene torch and not the means to do babbitt work. How many years have past since its day.
Hank
Post by Norman Kling » Thu Mar 25, 2021 11:52 am
It surprises me that someone would do that! They would need to remove the cap to braze the crankshaft. More babbit could have been soldered to the cap.
Post by Jerry VanOoteghem » Thu Mar 25, 2021 12:53 pm
Toss it...
Steve Bender
Last Name: Bender
Post by Steve Bender » Thu Mar 25, 2021 1:10 pm
I would think you would have to have removed the crank to do it. It would have been much simpler to take just the cap off and add babbitt. :roll:
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Mar 25, 2021 4:41 pm
If they did braze the crank while in the block... the bad thrust would have been the least of their problems. Cuz the center main bearing would have been on the FLOOR! :lol:
Steve Bender
Last Name: Bender
Post by Steve Bender » Thu Mar 25, 2021 4:53 pm
Agreed they must have done it out of the block or the babbitt would have melted out. The surface is built up so much I don't think a cap would fit.
