Carb adjusting rod
tommyleea
First Name: Tommy
Last Name: Russell
Carb adjusting rod
Post by tommyleea » Thu Apr 01, 2021 10:37 pm
23 T Roadster...Do any of you have problems with your carb adjusting rod, firewall to carb, turning on its own? When I get mine adjusted to where I want it, the vibration of the T seems to make the adjustment turn. I must be missing something that would put some friction on this rod..I don't have a grommet in the firewall. Maybe that is what's missing? Thanks...Tommy
Afrazer
First Name: David
Last Name: Frazer
* REQUIRED* Type and Year of Model Ts owned: 1925 closed cab TT. 1925 factory roadster pickup. 1926 two door sedan
Re: Carb adjusting rod
Post by Afrazer » Thu Apr 01, 2021 10:56 pm
Had the same problem on a Kingston L4 carb. I just replaced the carb adjustment needle clamp nut and snugged it down real good and that solved that problem the remaining time I had that carb on the car. The old clamp nut must have been wore down on the inner diameter and wasn’t holding the needle under driving vibration anymore.
1925 closed cab TT
1926 two door sedan
Post by Allan » Thu Apr 01, 2021 11:55 pm
David nailed it. Just tighten/replace the brass nut that clamps the mixture needle.
tommyleea
First Name: Tommy
Last Name: Russell
Post by tommyleea » Fri Apr 02, 2021 9:00 am
Thanks..Will do..Tommy
Post by Mark Gregush » Fri Apr 02, 2021 10:28 am
Don't go hog wild getting it tight. Snug enough that the rod does not turn on it own, but loose enough that you can still turn it without forcing it.
tommyleea
First Name: Tommy
Last Name: Russell
Post by tommyleea » Fri Apr 02, 2021 10:36 am
Copy..Thanks
