bending pedals
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
bending pedals
Post by Bruce Compton » Fri Apr 02, 2021 5:39 pm
Is it safe to bend the pedals on a '26-'27 hogshead to fit the floorboard spacing of a 1925 T? Not sure but I think that only the clutch pedal spacing is different, and should I bend them hot or cold?
Last Name: Juhl
Re: bending pedals
Post by Oldav8tor » Fri Apr 02, 2021 5:55 pm
Would it be easier to change the floorboards?
Erik Barrett
First Name: Erik
Last Name: Barrett
Re: bending pedals
Post by Erik Barrett » Fri Apr 02, 2021 6:01 pm
Bend them hot. It won’t bother them and you can get more accurate bends.
Joe Bell
First Name: Joe
Last Name: Bell
Re: bending pedals
Post by Joe Bell » Fri Apr 02, 2021 6:04 pm
I put a pipe wrench on them and bend them all the time, if they are out I use an anvil and big hammer, they bend easily!
Re: bending pedals
Post by speedytinc » Fri Apr 02, 2021 6:24 pm
If you rebend a late low pedal to fit your early floor boards, it will end up much taller than the other 2 pedals.(ugleee)
The proper way is to change the clutch & brake pedals to the earlier style.
2nd best is to change (remake) the floorboards.
Pedals bend real easy with 2 pipe or auto wrenches.
Re: bending pedals
Post by RajoRacer » Fri Apr 02, 2021 6:25 pm
This is the Ford factory bending iron ! You can see the script & Z number.
I'd change out the floorboards !
Re: bending pedals
Post by John kuehn » Fri Apr 02, 2021 6:50 pm
That’s a tool that can easily be made. Or as some do use a large pipe wrench or a good sized adjustable crescent wrench.
John Warren
Last Name: Warren
Re: bending pedals
Post by John Warren » Fri Apr 02, 2021 7:10 pm
I bent my pedals out using a torch to better accommodate my 10 1/2 D
[/size]
Re: bending pedals
Post by RajoRacer » Fri Apr 02, 2021 7:41 pm
Sure could John - I just happen to collect original tooling for Ford Model T's !
John Warren
Last Name: Warren
Re: bending pedals
Post by John Warren » Fri Apr 02, 2021 7:48 pm
Cool seeing the tool.... Haha 😄thanks
Bruce Compton
First Name: Bruce
Last Name: Compton
Re: bending pedals
Post by Bruce Compton » Fri Apr 02, 2021 8:27 pm
Thanks Guys; This is on a '26-'27 rebuilt engine/trans that a guy wants to put into a 1924 car so I don't think he wants to change the floor boards. I guess the next best thing is to change the pedal but that's beyond his capability, so he might end up bending the clutch pedal to fit his boards.
John Warren
Last Name: Warren
Re: bending pedals
Post by John Warren » Fri Apr 02, 2021 8:44 pm
I will agree that you can easily change the floor boards. The 26/27 pedals are just better and safer, unmodified.
Re: bending pedals
Post by John kuehn » Fri Apr 02, 2021 8:52 pm
I installed som pedal extensions to accomadate my size 13!
AndyClary
First Name: Andrew
Last Name: Clary
Re: bending pedals
Post by AndyClary » Fri Apr 02, 2021 8:56 pm
Just change the floor boards. Patterns available or just buy new. I’ve done it several times. Much easier than bending pedals and trying to make them look right.
Andy
Re: bending pedals
Post by Norman Kling » Fri Apr 02, 2021 9:16 pm
If you use the 26-27 pedals, they will not look correct for your car anyway, so just make a new floorboard for it. To change to the earlier pedals you would need to remove pin where the pedal as attached to the shaft and put in a new pin. That's a lot of work. But it would be better either way than to bend the pedal shaft to fit the floorboard. You can even save the original floorboards in case some time in the future, you change back to the original transmission or pedals.
halftracknut
First Name: randy
Last Name: lee
* REQUIRED* Type and Year of Model Ts owned: 1926 pickup
Re: bending pedals
Post by halftracknut » Fri Apr 02, 2021 10:34 pm
john warren that bend is a fantastic idea... I will do mine that way....thanks
John Warren
Last Name: Warren
Re: bending pedals
Post by John Warren » Fri Apr 02, 2021 11:22 pm
No regret, and if someone wants to bend them back sometime in the future, they can.
Much, much better for me.
Alan Long
First Name: Alan
Last Name: Long
Re: bending pedals
Post by Alan Long » Fri Apr 02, 2021 11:44 pm
John Warren’s idea is a great one! With my large feet I have to remove my size 13 shoes to drive my T’s. This is how I learnt
that the pedals get real hot and I need the rubber pads!!
Alan in Western Australia
