How do I fix this ?
Larry e rutt
Last Name: Rutt
* REQUIRED* Type and Year of Model Ts owned: 1926 fordor
How do I fix this ?
Post by Larry e rutt » Sun Apr 04, 2021 4:53 pm
So I put on a new flat tube radiator and can't adjust the spacing of the hood properly.. the problem is I only have a half inch between the fan and radiator.
Larry e rutt
Last Name: Rutt
Re: How do I fix this ?
Post by Larry e rutt » Sun Apr 04, 2021 4:55 pm
Sorry thing to post a picture
namdc3
First Name: Nikolaus
Last Name: Martin
Post by namdc3 » Sun Apr 04, 2021 5:08 pm
I see you have a ‘26. You might have a long fan hub for a thin core, and the new radiator is a full thickness core. You might need to just find the short version of the fan hub.
Post by Wayne Sheldon » Sun Apr 04, 2021 5:09 pm
What era fan and/or bracket? 1909 to about 1919? About 1918 to 1925? 1925 to 1927? If 1925 to 1927, which of at least three variations?
The brass era brackets are almost fool-proof. The about 1918 to 1925 brackets can actually be put on backwards. I forget which way does what, but the forward to back placement does shift a bit. The late 1925 through 1927 variations get more complicated. Also, there was a longer fan hub used for awhile that moved the fan closer to the radiator, (the radiator being used for a short while was thinner and needed the fan moved forward).
Best suggestions will need more information.
Larry e rutt
Last Name: Rutt
Post by Larry e rutt » Sun Apr 04, 2021 5:51 pm
Here r some pics that might help
namdc3
Last Name: Martin
Post by namdc3 » Sun Apr 04, 2021 5:59 pm
That is a long fan hub. It goes with a thinner core.
http://www.mtfca.com/discus/messages/50 ... 1448260540
Pep C Strebeck
First Name: Joseph
Last Name: M
Post by Pep C Strebeck » Sun Apr 04, 2021 6:25 pm
Post by John kuehn » Sun Apr 04, 2021 6:54 pm
You need the shorter version fan hub. You can call Lang’s tomorrow and ask if they have a good used short version. They also sell the newer ball bearing hubs that might fit but they would cost a bit more than an original used on. They do have a supply of used parts.
Post by RajoRacer » Sun Apr 04, 2021 6:58 pm
I have a bin full of hubs - drop me a note.
Post by TXGOAT2 » Sun Apr 04, 2021 8:15 pm
You need the correct fan hub. Also, the fan and hub should turn freely on the shaft, but there should be no wobble.
Larry e rutt
Last Name: Rutt
Post by Larry e rutt » Sun Apr 04, 2021 9:40 pm
So if I get the short fan hub I can move the top of the radiator back to fit the hood correctly, but can I move the bottom of the radiator back as well ?
Post by RajoRacer » Sun Apr 04, 2021 9:46 pm
The bottom spring mounts allow very little movement front to back - you'll need to loosen the bottom hose also - obviously, the top is adjusted with the brace rod & the upper hose.
Larry e rutt
Last Name: Rutt
Post by Larry e rutt » Sun Apr 04, 2021 10:02 pm
Ok.. thanks for the help.. ill put a short hub on and move the top back, maybe that will help a bit at the bottom as well.. even if the bottom doesn't move much it will look better..
