Coil Box Lid
tommyleea
First Name: Tommy
Last Name: Russell
Coil Box Lid
Post by tommyleea » Fri Apr 16, 2021 9:37 am
23 Roadster..Does the coil box lid secure the coils in any way? I don't have a lid for mine, and had a coil loose connection at the bottom contact. That made me wonder if a lid would have prevented this from happening. That being said, does anyone have a slant style coil box lid for a 23 roadster? Thanks..Tommy.
First Name: Keith
Last Name: Townsend
Re: Coil Box Lid
Post by KWTownsend » Fri Apr 16, 2021 10:24 am
The lid helps the coils stay in place and ensure proper contact inside the coilbox. Coils will tend to levitate if not properly secured.
Re: Coil Box Lid
Post by Mark Gregush » Fri Apr 16, 2021 10:35 am
The lids are the same from about 1917 to 1925. There is a lip inside that presses the coils down. So yes a lid will keep the coils seated.
tommyleea
First Name: Tommy
Last Name: Russell
Re: Coil Box Lid
Post by tommyleea » Fri Apr 16, 2021 10:59 am
Thanks...That is what I needed to know. The hunt is on..Tommy
Re: Coil Box Lid
Post by TRDxB2 » Fri Apr 16, 2021 8:08 pm
Caution on some of the reproduction slant top lids that have the sides and internal shelf spot welded which caused t he sides to warp. The shelf on the underside of the lid is what keeps the coils in place.
tommyleea
First Name: Tommy
Last Name: Russell
Re: Coil Box Lid
Post by tommyleea » Fri Apr 16, 2021 9:36 pm
Thanks for the heads up. I thought they would be easy to find, but not so. Tommy
Ruxstel24
Last Name: Hanlon
Re: Coil Box Lid
Post by Ruxstel24 » Sat Apr 17, 2021 6:06 pm
Tommy, I have a complete box with a good lid. Don't really want to separate them but would sell the set for $60 plus the ride...
Email me through the forum contact info if you're interested.
Dave
Re: Coil Box Lid
Post by Mark Gregush » Sat Apr 17, 2021 7:47 pm
Did you try putting an ad in the classifieds or looking on eBay?
Re: Coil Box Lid
Post by Original Smith » Sun Apr 18, 2021 10:49 am
I thought the 15-16 lids were used into early 17 too.
katy
First Name: Kenneth
Last Name: Todd
Re: Coil Box Lid
Post by katy » Sun Apr 18, 2021 11:28 am
TRDxB2. what are the hinges mentioned in the descriptions of the lids? I don't believe I've ever seen a coil box lid w/a hinge.
Re: Coil Box Lid
Post by Rich Eagle » Sun Apr 18, 2021 11:37 am
I suspect the description refers to the latch piece. The catch that mounts on the box itself sort of hinges to catch it.
Re: Coil Box Lid
Post by TRDxB2 » Sun Apr 18, 2021 12:00 pm
Sorry for the confusion. I corrected the image with the proper term see above
tommyleea
First Name: Tommy
Last Name: Russell
Re: Coil Box Lid
Post by tommyleea » Sun Apr 18, 2021 12:34 pm
Dave
Email sent..Thanks..Tommy
Re: Coil Box Lid
Post by TRDxB2 » Sun Apr 18, 2021 1:18 pm
Like most all parts transitioning from one year to the next - use up the old inventory. I also read that the date a part was manufactured doesn't always align with when it was available on the assembly line.
Re: Coil Box Lid
Post by speedytinc » Sun Apr 18, 2021 2:00 pm
My late 14/early 15 wide track has a 13 rear end. Being so uncommon & last in first out inventory, its not unreasonable to believe it came that way from the factory.
