Wrench and bead breaker
Michael Peternell
First Name: Michael
Last Name: Peternell
Post by Michael Peternell » Mon Apr 19, 2021 8:18 pm
Did some horse trading with my dad. What's the wrench for?
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: Wrench and bead breaker
Post by Erik Johnson » Mon Apr 19, 2021 8:31 pm
5-Z-249 is generator third brush wrench.
Michael Peternell
First Name: Michael
Post by Michael Peternell » Mon Apr 19, 2021 9:20 pm
Thanks! Please expand. Year?
Post by Norman Kling » Mon Apr 19, 2021 9:24 pm
The wrench would need to be for 1919 or later, because the earlier cars did not have a generator.
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Tue Apr 20, 2021 10:56 am
And used to adjust the output of your generator by moving the third brush's position...
Post by Mark Gregush » Tue Apr 20, 2021 11:45 am
Guess there were two styles of the wrench. I have seen others like the one shown without the end for taking off the nut that attaches the cut out to the post. I thought they were something someone modified, but guess not. It is used to loosen/tighten the nut that holds the 3rd brush so output can be adjusted. If you use it on running car, suggest wrapping it with tape in the bend area so does not short out on generator case.
