Rajo engine is done.
bowerss2
Topic author - Posts: 48
- First Name: Stephen
- Last Name: Bowers
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster; 1926 Speedster; 1912 Torpedo
Hey all, I thought I would share some photos of the engine that Mike Bender just finished building for me. Hopefully, I didn't drive him too crazy
He does good work. This is going back into my 26. I am trying to keep looking as close to something that an irresponsible young man would have put together in the late 20s early 30s as possible. Ok clearly that distributor is modern, and I am also putting juice brakes on the rear, but the rest of it I want to keep as authentic as possible. Went with red on the engine, because red is the fastest color.
got10carz
- Last Name: Meixner
Re: Rajo engine is done.
I never considered mounting the intake like that. Will it hit a generator or alternator?
bowerss2
- Last Name: Bowers
It will clear i believe. Its in that position for shipping. Im probably going to use a carter updraft. But i am going to try a few carbs on it first.
- Last Name: Hjortnaes
I think most of us are aware that a red engine goes faster than a black or green engine. Mike Bender does awesome work, and video's too.
Aussie16
- First Name: Warwick
- Last Name: Landy
- * REQUIRED* Type and Year of Model Ts owned: 1916 RHD Canadian Touring 1916 Pickup 1926 Fordor 1925 Dalgety Tourer 1916 Speedster
My dream engine. Please post pictures of the completed project when done.
dmdeaton
- First Name: Danny
- Last Name: Deaton
What oil pump are you using and got any more pics of the oil system?
Tim Rogers
- Last Name: Rogers
- Board Member Since: 2013
Les Schubert
- First Name: Les
- Last Name: Schubert
I am surprised that there isn’t a oil pickup screen
Don't flood it!
bowerss2
- Last Name: Bowers
There is, i just didnt include that photo.
It is a thing of beauty. Many of us are so envious.
Enjoy it.
Enjoy it.
How does the oil pump not loose its prime? I see. That pix was added after my question. Or my brain skipped a beat.
SurfCityGene
- First Name: Gene
- Last Name: Carrothers
Looks like a check valve right above the pick up screen maybe?
1912 Torpedo Roadster
Les Schubert
- First Name: Les
So I don’t see a oil filter. Where is it hiding!!
You could run I-35 down in South Texas and get a speeding ticket in an 85 MPH zone with that. If the check valve is spring loaded, be sure it will open on demand, every time, and be sure it isn't too restrictive.
tman1913
- First Name: Mike
- Last Name: Bender
- * REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
I will answer a couple of question as the OP doesn’t have the answers.
Oil filter. In a box, on a cart in my shop.
Check valve. Yes spring loaded
It will open at a very very low crack pressure
It will flow more oil than the pump will need to supply mains and rods. Not my first rodeo here guys.
dmdeaton
- First Name: Danny
- Last Name: Deaton
I am not asking to check your work, I am asking to learn.tman1913 wrote: ↑Mon May 03, 2021 1:30 pmI will answer a couple of question as the OP doesn’t have the answers.
Looks like the oil pump is driven from the back of the cam? What style of pump?
Great looking engine Mike, I love this stuff.
Danny
