Ford Faithful Oil System
Topic author - Posts: 24
- Last Name: Pakuris
- * REQUIRED* Type and Year of Model Ts owned: 14,24 TOURING 15 OPEN EXPRESS
Hello does anyone have one of these kits on their car . Not to much information out there on them. Want to know if it's a good investment.
Re: Ford Faithful Oil System
Doing a google search of "mtfca; Ford Faithful" there are lots of entries from post on this forum, these should help;
https://www.google.com/search?client=fi ... d+faithful
Thank's a lot that's quite a bit of info.
- First Name: Susanne
- Last Name: Rohner
I have one, it's a better system (IMO) than the original Ford internal line IF YOU KEEP YOUR LINES TIGHT, mine flows a LOT of oil to the front of the motor... after running it I can't see a reason NOT to... it's like free oil for the front of your pan!
I will be putting one on my 25 when I pull the engine. I will not be using the attachment to bottom of the inspection plate, will be plumbing it in to side of pan in about the same area.
I plumb mine through the pan - makes it much easier to remove the lower cover for maintenance !
