Just how tuff our T Models are
tman1913
Last Name: Bender
* REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
Post by tman1913 » Sat May 08, 2021 6:55 pm
It amazes me just how much punishment Henry's Model T can take and still ran.
I have seen a lot of loose rivets over the years when dealing with transmissions. All or some loose but never seen this before.
This had to happen over a period time, but yet kept on running. I slipped the shaft forward just for the picture.
First Name: Keith
Last Name: Townsend
Re: Just how tuff our T Models are
Post by KWTownsend » Sun May 09, 2021 1:07 am
Just like Timex watches.
It takes a lickin', and keeps on tickin'.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Sun May 09, 2021 7:29 am
Keith, I wonder how many of us remember those commercials? ;) :) :) Dave
1925 mostly original coupe.
Post by Jerry VanOoteghem » Sun May 09, 2021 7:58 am
Just after purchasing my '21 Roadster, my dad drove it home, maybe 40 miles. He mentioned that the rear end was a little noisy, so he thought we'd better have a look inside. When we split the housing, the whole differential fell out in pieces. The differential carrier was broken and in pieces and only held together by being squeezed between the thrust washers. Everything inside was total junk. Yet, it worked fairly well. What forgiving little cars these are!
Last Name: Wrenn
Post by TWrenn » Sun May 09, 2021 9:11 am
Not in my case!! :lol: Ironic for this post, cause earlier this week I posted this pic for the same reason. Pic shows the only rivet left...poor thing tried, but just couldn't do it!! Sadly my Fordor was left dead on the road!
Post by TXGOAT2 » Sun May 09, 2021 10:06 am
What symptoms would loose rivets at that point exhibit that a driver could detect?
Post by speedytinc » Sun May 09, 2021 11:27 am
That doesnt happen on its own. Thats the result of serious pan misalignment and/or transmission main shaft not running true. How many guys know to check the drive plate output shaft after assembling their transmission to the motor? Trust but verify.
Post by Steve Jelf » Sun May 09, 2021 11:40 am
Recently there was a video on one of the FB Model T pages showing an engine with the head off and the guy rotating the pistons back and forth about an inch. He said it had been running OK that way.
Post by Jerry VanOoteghem » Sun May 09, 2021 4:51 pm
Lots of vibration. A clunk when going from forward to reverse, (or reverse to forward), or starting off after a stop. In extreme cases, if the car is moving: no brakes, if the car is sitting still: won't move.
Post by speedytinc » Sun May 09, 2021 5:21 pm
4th main would be leaking a lot of oil from excessive wear also.
Post by TXGOAT2 » Tue May 11, 2021 5:48 pm
Thanks. Mine must be OK.
Post by Allan » Wed May 12, 2021 9:32 pm
They'll even get you home when the universal joint cage splits completely. In my youth I had this happen some 40 miles from home. The two yokes still drove by running against one another. The noise gets quite high, the heat melts the whitemetal out of the fourth main, but the old clunker still got two youths home by midnight.
