How to Remove Glass from Rear/Quarter Panel Windows
Topic author - Posts: 892
- First Name: Bruce
- Last Name: Brakke
I am in the process of removing the glass from the windows in my 1927 coupe. The photos show the windows. I have removed the hardened rubber on the inside of the rear window, but I haven't tried to "push" the glass out. I would appreciate any comments/suggestions on how to proceed.
- First Name: Bruce
- Last Name: Brakke
Re: How to Remove Glass from Rear/Quarter Panel Windows
I got the glass out of the three windows. Chipped the hardened rubber out on the inside and carefully pushed each out.
- Last Name: Warren
Well now who is the expert! Thanks for sharing.
- Last Name: Patrick
Just what I would have advised. Glad you figured it out on your own. Usually the most obvious solution is the correct one (see “Occam’s Razor”). The more experience you get in working on this beautiful T, the more confidence you will find, until the forum is the last resort. Good job. Keep it up. Jim Patrick
PS. New rubber is available from Snyder’s, Lang’s and the other suppliers.
