How do I get this bolt into that hard-to-reach place?
Post by Steve Jelf » Tue May 25, 2021 11:36 am
Tongue depressor, Gorilla tape.
RGould1910
Last Name: Gould
Re: How do I get this bolt into that hard-to-reach place?
Post by RGould1910 » Tue May 25, 2021 12:06 pm
Oh yea! Like the pan arm to frame nuts. Good idea!
Post by speedytinc » Tue May 25, 2021 12:23 pm
I use a long hemostat clamp. (aka roach clip) Upper pan arm bolts & inner arm nuts.
Post by RajoRacer » Tue May 25, 2021 1:11 pm
"Chinese" fingers with one of the four tangs removed works also.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Tue May 25, 2021 1:20 pm
I tied ends of a 2-foot piece of dental floss after threading it through the cotter pin hole of a pan ear bolt. I stuck a thin wire through the pan ear's hole, snagged the floss and pulled the bolt through. Holding tension on the floss, I threaded it through the nut and dropped the nut onto the bolt. I have a photo but it won't load.
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Tue May 25, 2021 1:21 pm
I use this .
Toon
Post by John kuehn » Tue May 25, 2021 1:58 pm
I’ve always wondered how those guys at the Ford factory did it!
Stephen_heatherly
First Name: Stephen
Last Name: Heatherly
Post by Stephen_heatherly » Tue May 25, 2021 3:24 pm
I tape the bolts in the end of a box end wrench so they can't fall out.
Stephen
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue May 25, 2021 3:44 pm
Box wrench or combo wrench end with strip of shop towel crammed between wrench head and bolt head. Locitite makes a product called Fun Pack that is like silly putty but stickey. A piece of electrical tape crammed in the wrench head works in a pinch as well.
tommyleea
First Name: Tommy
Last Name: Russell
Post by tommyleea » Tue May 25, 2021 4:00 pm
See what you started..
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Tue May 25, 2021 4:32 pm
Working as a mechanic I always kept gum wrappers to wedge nuts and bolts into wrenches and sockets.
Andy
Post by TRDxB2 » Tue May 25, 2021 5:10 pm
Ans once the bolt/nut is positioned I ratchet it in. Tape the nut to the end with Frog Tape is tough, sticky and shows up in dark places :)
YellowTRacer
First Name: Ed
Last Name: Archer
Board Member Since: 2009
Post by YellowTRacer » Tue May 25, 2021 5:35 pm
Dan has it right. The old Sala method. Don't need anything special. Just lay the open end/box end wrench down on the bench, lay a light rag or paper towel over the box end and push the bolt head first down into the "box" and you're ready to go. It doesn't even have to go all the way into the box, it gets tight right away, Go for it!
Ed aka #4
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Post by Jim Eubanks » Tue May 25, 2021 5:38 pm
I just weld a nut on the pan ear when the pan is off.
Post by John kuehn » Tue May 25, 2021 6:19 pm
I use tape on the end of a box end wrench to hold the nut or bolt in place then screw the nut on. I use lock washers in those areas instead of using cotter pins. I don’t think Henry would mind by now! :)
Post by Mark Gregush » Tue May 25, 2021 10:49 pm
Welding would work but have been doing the same as John for a lot of years to hold the nut for the bolts thru the wood blocks and pan ears on the starter side.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Tue May 25, 2021 11:08 pm
16 year old Daughter.
