Gas pump nozzle clip?
Topic author - Posts: 1510
- First Name: Keith
- Last Name: Townsend
For those of you that live in areas with vapor recovery boot of gas pumps, you'll know what I am talking about.
I filled up one day and the guy handed me his "gas clip" out of his back pocket. It was made out of aluminum and it held back the boot that otherwide needs to be held with your hand while filling the gas tank. Otherwise it will shut off after you put about 2 gallons in...
I know motorcycle guys would appreciate one of these, too.
Anyone know where I can find one, or have dimensions so I can fabricate one?
Thanks,
Keith
Thanks,
Keith
Re: Gas pump nozzle clip?
That would be especially useful in filling a 26-27 or a Model A.
George Mills
- Last Name: Mills
- First Name: Keith
I already checked with them. They are out of stock until late June...
Should be easy to make
Found this : Nozzle size standard dictates that the delivery nozzles for unleaded fuel shall not exceed 0.85" in diameter while the delivery nozzles for leaded fuel shall not be less than 0.93" in diameter.. However if the bellows are and EVR type ( Enhanced Vapor Recovery) the pad needs rest flat enough to cause a suction.
- Attachments
- EVR.png (213.12 KiB) Viewed 2931 times
Novice
- First Name: Jim
- Last Name: Davis
Should be a snap to build as many as You want with a 3-D printer.
Fab one from plexiglass or lexan. Can't be that hard to do.
I've been using my left hand for years with no problems!
Kaiser
- First Name: Leo
- Last Name: van Stirum
I think that is an inappropriate remark Larry, this is a family show
Leo van Stirum, Netherlands
