Anybody Know What This Is
mt15
Topic author - Posts: 40
- First Name: gary
- Last Name: griffin
I had this for years. Not even sure where I got it.
I’ve had it at my Chickasha booth several times. A lot of theories
Theories but know positive ID’s
KeithG
- First Name: Keith
- Last Name: Gumbinger
Re: Anybody Know What This Is
It's a valve spring compressor.
Keith
Keith
mt15
- First Name: gary
I can see that!
A lot of people thought it was a speedometer cable/head/swivel tool.
I give it a try and see how it works.
thanks
thanks
Not a valve spring compressor - it's an early Ford speedometer cable end wrench.
Russ_Furstnow
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
It is not a speedometer swivel tool. It appears to me to be a valve spring compression tool. Here is a photo of the swivel tool..similiar but not the same. Russ Furstnow
What do I know ? I thought I'd seen that shape before ! A ruler for scale might have helped ?
Here's a similar lift, dual ends. The Ford valve end is noted. Found on the web.
kmatt2
- Last Name: Matthiesen
Steve, Check out second picture with the ruler, it shows the tool to be about 3.5 inches. I don't know what tool is used for.
I really did go in recently for an eye exam !!!
D Stroud
- Last Name: Stroud
- Board Member Since: 2011
I may be way off base here, but I think that may be a tool for FORD watermeters. They use the block letters like that. JMHO Dave
1925 mostly original coupe.
- Last Name: House
Naw...! Its a shoehorn for Ford employees
