Hello Forum,
Looking for advice on the preffered method of removing the inner race from the spindle on an early car with roller bearings. I was able to get one side off with some gentle heat and persuasion but not so lucky on the other side. Not looking to destroy the race (or spindle) if I can help it. Haven't seen any info on this in the search just discussion on removing the race from the hub. Any help is appreciated. Thanks!
Inner wheel bearing race removal advice
Topic author - Posts: 60
- First Name: LORIEN
- Last Name: HEGNER
Re: Inner wheel bearing race removal advice
Try 2 wood chisels, opposite sides, in the crack under the race. Can heat first. If it wont come, a couple stubs (like 2 nuts) can be welded to the race. Use the stubs as something to bite on in a press. Repair after grinding off the stubs.
Lorien, when you do get it out, don't be afraid to take a die grinder and make a couple of grooves inside the hub like the later hubs have. That will let you drive out any subsequently fitted cones.
- Last Name: HEGNER
Thanks guys! I was able to get it off by welding a couple beads and using a chisel. It is toast but wasn't the best to begin with. Thought I'd keep as a spare but in the scrap it goes!
Here's what Allan referred to.
