McMillan cylinder head questions
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Tue Jun 01, 2021 2:51 pm
I will be beginning the finish machining operations and rocker fabrication on a McMillan overhead valve cylinder head casting ... many of the operations are clear , standard operations ... i am interested in any information regarding the placement and type of spark plug used ... any photos or drawings of a finished cylinder head would be appreciated ...always an optimist ...Gene French
McMillan head.jpeg (49.89 KiB) Viewed 1726 times
McMillan head2.jpg (37.09 KiB) Viewed 1726 times
McMillan head1.jpg (32.78 KiB) Viewed 1726 times
Tim Williams
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1925 Model T Speedster, 1922 Model t Speedster project
Re: McMillan cylinder head questions
Post by Tim Williams » Tue Jun 01, 2021 7:28 pm
I talked to Chis Becker, and he said he is calling someone who is familiar with the head and should be in touch with you soon.
Tim
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Jun 01, 2021 7:41 pm
My dad has one on the shelf... I’ll snap a couple pics next time I’m over👍
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Wed Jun 02, 2021 8:53 am
Kevin:
thank you ... pictures would be helpful ... i want to be careful with the spark plug placement since i don't have any info. on foundry patterns and material thickness ... i am certain that the plugs will be centered in cylinders on the intake side ,BUT , may be angled and elevation is uncertain ... any help is appreciated ...always an optimist ...Gene French
