Layne Warford
Nunsio1
Last Name: Monticciolo
* REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
Layne Warford
Post by Nunsio1 » Fri Jun 04, 2021 2:13 pm
Has anyone shortened the shift lever on a Layne Warford. If so what length is good,can it be done with out removing the shift assembly? This will make climbing in & out a bit easier.
Thanks in advance for your help.
John Monticciolo
Oscoda, Michigan
24 C Cab Truck
Re: Layne Warford
Post by Allan » Fri Jun 04, 2021 7:11 pm
John, I didn't shorten mine. I bent it back further and added about 6" so it nestles next to my knee. No reaching, no problems getting in.
Model T Mark
Last Name: Eyre
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
Re: Layne Warford
Post by Model T Mark » Fri Jun 04, 2021 9:04 pm
I did mine too 6 inches off. Put it in neutral unscrew the cap lift it up. Shorten it then reinstall. I did it on a 26-27 roadster pickup because I couldn’t get over it entering the car from the passenger side. The driver’s side is pretty useless with the spare in the way.
KeithG
First Name: Keith
Last Name: Gumbinger
Re: Layne Warford
Post by KeithG » Fri Jun 04, 2021 9:48 pm
I also have a Layne Warford in my '26 Roadster Pickup. I don't have a problem getting in or out on the right side, but when driving on a tour, the shift knob hits my right knee just right to be quite uncomfortable. I'm thinking of bending the shift lever about 2" to the right with the bend to be about 6" above the floor. Has anyone done something like this?
Other than that, I really like the Layne Warford!
Thanks,
Keith
Re: Layne Warford
Post by speedytinc » Fri Jun 04, 2021 10:03 pm
I have seen the shifter as short as 8" on a speedster. Leave it high enough to comfortably shift on the fly.
Dennis Prince
Last Name: Prince
Re: Layne Warford
Post by Dennis Prince » Fri Jun 04, 2021 10:24 pm
I did shorten the shifter, I bought a car with a KC Warford in it that had been rolled and the reason that it rolled is because it got knocked into neutral because the shifter stuck up above the seat so I modified it so it no longer sticks way up there. One thing it does do is shorten the throw of the shifter and it takes a little getting use to.
Sarikatime
Last Name: Seress
Re: Layne Warford
Post by Sarikatime » Sat Jun 05, 2021 3:26 pm
This is a cast iron warford that was always in my way. I heated the solid rod with the top bend first and then the lower bend about two inches to the right. It is still full height but easy to get in and out and not in my way. Frank
dobro1956
First Name: Donnie
Last Name: Brown
Re: Layne Warford
Post by dobro1956 » Sat Jun 05, 2021 3:53 pm
On my 27 touring I reversed the shifter in the housing. Just remove the shifter, turn it 180 degrees and re-install. It will fit either way. That makes it sit close to the seat. Then I shortened it so the top of the shift knob is at the top of seat cushion or slightly above it. Leave it just tall enough so you can use the palm of your hand to "bump shift" it and not hit the seat cushion with your hand and be low enough so you leg can slide over it when getting in or out of the car.. When I get out of the car my leg will slide "over" the shifter and it does not interfere with getting in or out. With the shift knob sitting close to, and protected by the seat cushion, there is less chance for it to get knocked out of gear by accident. It has worked very well for my 27 touring. You may need to slightly bend the shifter to get the knob to sit where you need it on different years or body styles. I just heated the shifter shaft with a torch and slightly bent it to be how I wanted it to sit when in second and third gear.
