Repair/Maintenance Books
acereske
Topic author - Posts: 10
- First Name: Al
- Last Name: Cereske
- * REQUIRED* Type and Year of Model Ts owned: ‘26 coupe
Ford Model A owners have books by Les Andrews. Who does Ford Model T owners have?
Kerry
- Last Name: van Ekeren
Re: Repair/Maintenance Books
Henry Ford.
- First Name: Adrian
- Last Name: Whiteman
MTFA series,
Often referred to as the "Black Bible"....indispensible. Mine is almost worn out, full of greasy fingerprints!
https://www.modeltford.com/item/T1.aspx
Don't forget the DVD's put out by the club and available from the parts suppliers. Our club has a number of those that can be checked out by the members, so check your local club. Also there are a number of YouTube videos. https://www.youtube.com/playlist?list=P ... 1nA0Yctp6G
http://dauntlessgeezer.com/DG80.html
Also online Modelt-tips videos by Mike Bender and others, and online videos by Mitch Taylor.
PDGx
- First Name: Paul
- Last Name: Grohsmeyer
You are right - The Model A Les Anderson books are awesome ! The details go as far as telling what wrench size is needed for each operation. The third book goes into all of the common upgrades.
Never have found anything close to these for the T/TT.
Ah. Takes all the fun away. Got my first T as teen, wretched on it, ground valves, changed # 1 rod before any books. Didn’t know the Service Manual existed!
jwilliams81
- First Name: Jarrod
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1923 Touring with electric starter, low radiator
Is there a larger print version of the black bible (Model T Ford Service Manual) available?
I'm 40 and also have the Les Andrews books for my Model A, and struggle reading and learning from the black bible.
Yes. Since you have a pc, buy the CD version of McCalley’s Encyclopdia
It has The Book…..(Ford Service) and you can scan, enlarge, or print to your heart’s content.
http://www.mtfca.com/discus/messages/822076/844722.html
Shared via the Google app
Sent from my iPad
Sent from my iPad
Re the service manual for us that like "BOOKS", larger print; https://www.ebay.com/itm/124750125178?h ... SwgQ9VksZa
