Correct Connection of Starter Brushes
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Tue Jun 08, 2021 8:06 pm
Putting a starter together after overhaul.
Do the starter field leads attach to the INSULATED set of brush holders?
Or the HOT SET of brush holders?
Logic tells me that the field coil leads should attach to the INSULATED brush holders, thus making the electrical path FROM the main terminal, to the insulated brush holders, thence through the armature (turning the armature) and then from there out the GROUNDED brush holders, and out the case to the ground on the engine/starter machined face. Is t his correct?
I have watched a few videos on the subject, but the guy never addresses this, and he has his hand over whatever he is discussing, so it is not possible to see what's going on.
Ron Patterson
Re: Correct Connection of Starter Brushes
Post by Ron Patterson » Tue Jun 08, 2021 8:18 pm
The Model T starting motor field winding pigtails are connected to the insulated brush holders.
Ron Patterson
Last Name: Hatch
Post by Dan Hatch » Tue Jun 08, 2021 9:41 pm
Ford Service manual tells how to do anything you want to do to a Model T.
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Tue Jun 08, 2021 10:27 pm
Thank you, Ron.
Dan: Unfortunately, the Model T Maintenance Manual is printed so small, that most of the pictures are nearly useless. If they ever reprint it, I hope whoever does it takes better pictures, and prints it in 8.5 X 11 size. It would then be far more useable than it is now.
Last Name: Hatch
Post by Dan Hatch » Wed Jun 09, 2021 3:53 am
Find an original one or the first reprint. They are on eBay often.
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Wed Jun 09, 2021 11:34 pm
I just ordered the cleaned up, large size reprint. It should be much more legible.
