Help for a friend
Last Name: Juhl
Help for a friend
Post by Oldav8tor » Thu Jun 17, 2021 11:19 am
A buddy of mine is going to pick up his first Model T (1922) next Tuesday. He helped me get my T going so I'm going to do the same for him. I have a couple of questions for the group.
1.) Is there anyone who will re-core a 1922 low radiator or is Bergs or Brassworks the only option to get a serviceable flat-tube radiator?
2.) Is there a guide anywhere on how to use a hand cranked coil tester (HCCT)? Another friend has a tester he got out of an old Ford dealership 50+ years ago and we'd like to get an idea of the condition of the coils. The previous owner of the T has been deceased a number of years and there is no info on what he did with the car restoration-wise.
I'm sure we'll have more questions....that's part of the fun :D
Re: Help for a friend
Post by Jerry VanOoteghem » Thu Jun 17, 2021 11:37 am
Tim,
Check with Steve Shotwell, I believe the Casual T's owns a Strobo Spark coil tester for the use of our members.
http://www.casualts.org/toolshare.htm
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Thu Jun 17, 2021 11:40 am
People have used local shops to re-core a radiator.
Be sure to see if they have experience with antique radiators.
Here is a link to the HCCT Handbook sold by MTFCA.
https://modeltstore.myshopify.com/colle ... -patterson
Respectfully Submitted,
Be_Zero_Be
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Thu Jun 17, 2021 11:41 am
Any radiator shop that does repair work should be able to re-core any brass radiator. The shop here in New Orleans told me that I could have my non-T radiator replaced or re-cored for the same price (about $300). They would just reuse the top and lower tanks. The question is will the core look original, or does that matter to you.
Vern (Vieux Carre)
Post by Jerry VanOoteghem » Fri Jun 18, 2021 7:17 am
Not true. I've seen some real butcher jobs. The biggest problem seems to be that, unless they have worked on early radiators, they don't realize that these radiators can be seen and have to look nice and also have to fit within a close fitting radiator shell.
Last edited by Jerry VanOoteghem on Sat Jun 19, 2021 8:53 am, edited 1 time in total.
dhosh
Last Name: Hoshield
* REQUIRED* Type and Year of Model Ts owned: '24 RPU (Raodster converted to Pickup)
Post by dhosh » Fri Jun 18, 2021 9:02 am
I had my radiator (24 roadster) recorded by Ferndale radiator, I believe. My overheating issues are now home! That was about 4-5 years ago. Aparently, he has done a lot of old radiator cores. It looks and works fine for me.
'24 RPU
Petoskey, Mi
Last Name: Juhl
Post by Oldav8tor » Fri Jun 18, 2021 10:04 am
Thanks Dennis - Ferndale is an easy road trip so I think we'll check them out once we get the T home. Jerry, the buyer is a Casual T member so we're adding another T to the club.
Duckwing
First Name: Jim
Last Name: Wilson
Post by Duckwing » Fri Jun 18, 2021 1:47 pm
Ditto re making sure the shop you go to has experience with antique auto radiators. Years ago, I spoke to several radiator shops who were honest and didn’t feel they could do the job. I finally found a shop that had an elderly gentleman that only worked on antique radiators. He worked part time at his own pace but got my work done. The owner said he wouldn’t let any of his other guys touch my radiator.
Last Name: Juhl
Post by Oldav8tor » Fri Jun 18, 2021 8:08 pm
It seems that the only guys to be trusted with our radiators are near or beyond retirement age. My go-to guy retired recently and the fellow he referred me to said he's going to retire this October. It's a dying art in today's throw-away society.
Post by Mark Gregush » Fri Jun 18, 2021 8:46 pm
Our go to guy was in his early 30's. He did great work, learned from his Dad and Grandpa, just could not make enough to keep the shop open and now is selling auto parts. :cry:
jsaylor
Last Name: Saylor
Post by jsaylor » Sat Jun 19, 2021 12:20 pm
I have had three black re-cores over the years. The first two done in the late 60's. both were done without the stiffening bar that runs mount to mount. Cost about $35 back then. I still have one of those cars, 21 Touring. The radiator ran for about 30 years but developed small leaks at the solder joints. and I finally bought a new one. I believe the absence of the stiffening bar contributed to the leaks. My last re-core 27 Tudor, was in 1994. The shop was able to obtain a new core with the correct stiffening bar. It cost me $375 out the door. Now here in the Sacramento- Auburn area re-cores without the bar are running $550. For just a little bit more you can buy a new Berg's or Brassworks and never have to worry about it ever.
John_Aldrich
Last Name: Aldrich
* REQUIRED* Type and Year of Model Ts owned: 1915, 1923. 1927
Post by John_Aldrich » Sun Jun 20, 2021 6:53 pm
I've had good luck by simply telling the radiator rebuild shop that this isn't a pressurized system. Have had three re-cored.
John Aldrich
Typical Model T Addict
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sun Jun 20, 2021 7:27 pm
Just make sure they understand its not pressurised. I told a local shop that and they called and said it needed recored. I said it was a small leak. He told me it really started leaking at 7lbs and at 10lbs it leaked everywhere. I now have a recore.
